| 0001270 | FreeCAD | Bug | public | 2013-10-11 22:24 | 2017-03-27 08:30 |
| Reporter | pkoning | Assigned To | yorik | ||
| Summary | 0001270: Raytracing export produces bad light definition | ||||
| Description | The "write the active 3d view" operation produces a POV file that has two copies of the default light definition (light_source command). They look identical, and they are written in terms of the camera location. But the first one is inserted before the camera location is declared, so POVray complains. Deleting that one makes it work. The bad one shows up just after the "//RaytracingContent" comment in the generated file. | ||||
Is this version 0.13.1828? In the developer version there have been changes recently which solved a lot of glitches. |
According to the About box: Platform: Mac OS X (64-bit) Version: 0.13.1349 (Git) Branch: master Hash: c2955998282fa63acab0d513e4a70382105ae236 Python version: 2.5.6 Qt version: 4.8.3 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.3 BTW, the font on that box is about 4 point type, nearly illegible (on the Mac) |
Ah indeed. The template system has changed, now the freecad contents is not inserted simply at the end, but at the //Raytracingcontent tag. This "write the active 3d view" command needs to be adapted too, I'll take care of this. |
Fixed with commit bac709b |
| 2013-10-11 22:24 | pkoning | New Issue | |
| 2013-10-12 07:05 | wmayer | Note Added: 0003736 | |
| 2013-10-12 13:01 | pkoning | Note Added: 0003738 | |
| 2013-10-12 13:03 | yorik | Note Added: 0003739 | |
| 2013-10-12 13:03 | yorik | Status | new => assigned |
| 2013-10-12 13:03 | yorik | Assigned To | => yorik |
| 2013-10-12 14:54 | yorik | Note Added: 0003740 | |
| 2013-10-12 14:54 | yorik | Status | assigned => closed |
| 2013-10-12 14:54 | yorik | Resolution | open => fixed |
| 2013-10-12 14:54 | yorik | Fixed in Version | => 0.14 |
| 2017-03-27 08:30 | Kunda1 | Changeset attached | => FreeCAD master bac709b2 |
