| 0001336 | FreeCAD | Feature | public | 2013-12-22 07:20 | 2017-05-23 04:35 |
| Reporter | peterl94 | Assigned To | DeepSOIC | ||
| Priority | normal | Severity | tweak | Reproducibility | N/A |
| Summary | 0001336: Increase the tolerance for selecting edges | ||||
| Description | It would be nice if the "hot spot" for edges was bigger. Currently, you have to click quite precisely to be able to select the edges of a concave area. One way to achieve this is to increase the tolerance when comparing intersection points in SoFCUnifiedSelection::getPickedPoint. I found a value of 1 worked well. | ||||
http://forum.freecadweb.org/viewtopic.php?f=8&t=5193&sid=6ee09fd97233f9a1f6635348556eac03 |
See also: https://forum.freecadweb.org/viewtopic.php?f=27&t=16275 |
Ha, I forgot about this. It has been resolved as seen in the above thread. |
Should I resolve it as 0.17 and attribute to whom? |
Yes. DeepSOIC is the one who implemented it. |
Closing ticket. |
| 2013-12-22 07:20 | peterl94 | New Issue | |
| 2013-12-22 11:24 | wmayer | Note Added: 0003961 | |
| 2017-05-22 14:20 | Kunda1 | Note Added: 0009083 | |
| 2017-05-22 20:30 | peterl94 | Note Added: 0009088 | |
| 2017-05-22 21:11 | Kunda1 | Note Added: 0009091 | |
| 2017-05-22 21:27 | peterl94 | Note Added: 0009092 | |
| 2017-05-23 04:35 | Kunda1 | Assigned To | => DeepSOIC |
| 2017-05-23 04:35 | Kunda1 | Status | new => closed |
| 2017-05-23 04:35 | Kunda1 | Resolution | open => fixed |
| 2017-05-23 04:35 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-05-23 04:35 | Kunda1 | Note Added: 0009095 |
