| 0001347 | FreeCAD | Feature | public | 2014-01-07 21:08 | 2021-02-06 06:50 |
| Reporter | bejant | Assigned To | |||
| Summary | 0001347: Reduce Rendering Time of Complex Objects | ||||
| Description | Reduce rendering time of complex objects resulting in faster Rotate, Pan, Zoom. This feature request is from the following forum thread: http://forum.freecad.org/viewtopic.php?f=3&t=5307 | ||||
| Tags | slow | ||||
wmayer writes in http://forum.freecad.org/viewtopic.php?f=3&t=5307#p42308 > Here the point is if you are in sketch edit mode and modify it the dependent features like pad, pocket or whatever shouldn't update automatically. > The request of andre is to reduce rendering time when you rotate or pan inside the 3d view because there we have for each little movement a complete redraw of the scene. For very complex objects this can be quite time consuming. > In the Mesh module we have implemented a way to reduce rendering time. If you have a mesh with more than 100,000 triangles then panning or rotation auto-flips to a point display. I have meshes with more than 5,000,000 triangles and panning/rotation is sufficiently fast. |
This ticket has been migrated to GitHub as issue 5577. |
