| 0001395 | Draft | Feature | public | 2014-02-09 14:42 | 2014-05-07 22:28 |
| Summary | 0001395: Draft - add a pref setting to disable auto-face in closed draft objects | ||||
| Description | This way things would be more unified between draft and sketcher. | ||||
Hm this is actually pretty dangerous... One could change the setting, open a file with suometing built in a draft object, then the imported object wouldn't be a face anymore, which would make the objects built on it fail. I must think to another solution, maybe a per-object property... |
Likely we'll need a per-object property that says if it must become a face or not... |
FreeCAD: master 96bba087 2014-05-08 00:03:00 Details Diff |
Draft: Filling objects with faces is now optional - fixes 0001395 Closable Draft objects now have a new MakeFace property, that specifies if they must be turned into a face or stay a wire only. Older Draft objects continue to behave the old way for compatibility. The default behaviour can be set in Draft Preferences -> Fill objects with faces |
Affected Issues 0001395 |
| mod - src/Mod/Draft/Draft_rc.py | Diff File | ||
| mod - src/Mod/Draft/Resources/ui/userprefs-base.ui | Diff File | ||
| mod - src/Mod/Draft/Resources/ui/userprefs-visual.ui | Diff File | ||
| 2014-02-09 14:42 | yorik | New Issue | |
| 2014-02-09 14:42 | yorik | Status | new => assigned |
| 2014-02-09 14:42 | yorik | Assigned To | => yorik |
| 2014-02-09 14:42 | yorik | Project | FreeCAD => Draft |
| 2014-02-11 21:02 | yorik | Note Added: 0004188 | |
| 2014-02-11 21:03 | yorik | Note Edited: 0004188 | |
| 2014-02-24 15:22 | yorik | Note Added: 0004291 | |
| 2014-05-03 16:25 | yorik | Relationship added | parent of 0001528 |
| 2014-05-07 22:28 | yorik | Changeset attached | => FreeCAD Master master 96bba087 |
| 2014-05-07 22:28 | yorik | Status | assigned => closed |
| 2014-05-07 22:28 | yorik | Resolution | open => fixed |
