| 0001528 | Draft | Bug | public | 2014-05-03 00:47 | 2014-05-07 22:39 |
| Reporter | JsnPrkr | Assigned To | yorik | ||
| Platform | Dell SmartTouch2 | OS | Win7 Home Premium SP1 | OS Version | Win7 Home Premiu |
| Summary | 0001528: Undo Wireframe Circle After Delete Generates Solid Disc | ||||
| Description | When a circle is deleted, invoking Undo brings it back filled in (a disc). | ||||
| Steps To Reproduce | Select a circle. Press [Delete] key. Press[Ctrl-Z]. Happens regardless of view setting (Top, Front, etc). | ||||
What appears to be happening is that the "Appearance>Viewing Mode" parameter of the undeleted object is set to "Flat Lines" after it's undeleted. This is what I found when opening the object's "Appearance..." dialogue. Setting the Viewing Mode to "Wireframce changed it back to the wireframe rendition. |
Indeed, the undo function doesn't reset the display mode to what it was. But I'll introduce in 0001395 a setting for the user to decide if the resulting shape must be filled or not, which should solve this bug too. |
This should now be solved by the changes in 0001395 |
| 2014-05-03 00:47 | JsnPrkr | New Issue | |
| 2014-05-03 01:04 | JsnPrkr | Note Added: 0004604 | |
| 2014-05-03 16:25 | yorik | Note Added: 0004615 | |
| 2014-05-03 16:25 | yorik | Assigned To | => yorik |
| 2014-05-03 16:25 | yorik | Status | new => assigned |
| 2014-05-03 16:25 | yorik | Relationship added | child of 0001395 |
| 2014-05-07 22:39 | yorik | Note Added: 0004641 | |
| 2014-05-07 22:39 | yorik | Status | assigned => closed |
| 2014-05-07 22:39 | yorik | Resolution | open => fixed |
| 2014-05-07 22:39 | yorik | Fixed in Version | => 0.14 |
