| 0001453 | FreeCAD | Feature | public | 2014-02-28 12:17 | 2019-07-29 15:17 |
| Reporter | shoogen | Assigned To | wmayer | ||
| Priority | low | Severity | minor | Reproducibility | N/A |
| Summary | 0001453: Use string representation for PropertyPlacement editor that presevers double precision | ||||
| Description | Currently editing the Placement Property in the GUI (either from the property view or form the placement dialog) degradges the precision. This happens due to the serialisation to a string with is then provided to the runCommand function (and thus to a recorded macro). Furthermore the description of a rotation in not intuitive an unexperienced user. For simple rotations, a description using Eulerian angles could represent the exact rotation with a few decimal places. Another viable description could be an Axis with an Angle. In this representation the python command would include calls to convert the angle to radians and normalize the axis vector. | ||||
| Steps To Reproduce | change the placement of an object to 30° around +z. the python window will show App.Rotation(0,0,0.258819,0.965926) obviously this value was rounded/truncated to 6 decimal digits, which roughly resembles single float precision. The value of the resulting rotation will differ because the normalization of the quaternion is performed with double precision. One example of the amount of error introduced: >>> ((1.0-App.Rotation(0,0,0.258819,0.965926).toEuler()[0]/30)).hex() '0x1.6b13c52200000p-22' | ||||
| Additional Information | QString::arg(d,0,'g',6) | ||||
| child of | 0000458 | closed | Problem fusing a cylinder with a torus (Probleme de fusion entre un cylindre et un tor) |
FreeCAD: master de727642 2014-03-01 11:41:42 Details Diff |
Affected Issues 0001453 |
| mod - src/Gui/Placement.cpp | Diff File | ||
| mod - src/Gui/Placement.h | Diff File | ||
FreeCAD: master 7ebfa363 2014-03-01 12:41:29 Details Diff |
+ fixes 0001453: Use string representation for PropertyPlacement editor that presevers double precision |
| mod - src/Gui/propertyeditor/PropertyItem.cpp | Diff File | ||
| mod - src/Gui/propertyeditor/PropertyItem.h | Diff File | ||
| 2014-02-28 12:17 | shoogen | New Issue | |
| 2014-02-28 12:20 | shoogen | Steps to Reproduce Updated | |
| 2014-03-01 10:42 | wmayer | Note Added: 0004336 | |
| 2014-03-01 12:09 | wmayer | Changeset attached | => FreeCAD Master master 7ebfa363 |
| 2014-03-01 12:09 | wmayer | Assigned To | => wmayer |
| 2014-03-01 12:09 | wmayer | Status | new => closed |
| 2014-03-01 12:09 | wmayer | Resolution | open => fixed |
| 2015-01-30 12:29 | shoogen | Relationship added | child of 0000458 |
| 2019-07-29 15:17 | Kunda1 | Changeset attached | => FreeCAD master de727642 |
