| 0001513 | Draft | Bug | public | 2014-04-18 02:03 | 2014-06-23 18:45 |
| Reporter | jmaustpc | Assigned To | yorik | ||
| Target Version | 0.14 | ||||
| Summary | 0001513: dxf export flipped arc | ||||
| Description | some of the arcs are flipped in a dxf exported from FreeCAD forum topic http://forum.freecadweb.org/viewtopic.php?f=10&t=4473&p=51114#p51110 OS: Ubuntu 12.04.4 LTS Platform: 64-bit Version: 0.14.3448 (Git) Branch: master Hash: 70df8540a768019966ace8825bf9b3e3fb6fab6f Python version: 2.7.3 Qt version: 4.8.2 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.7.0 | ||||
| Steps To Reproduce | export the multiTransform feature as a dxf file and you get the right hand slot with flipped arcs. This file attached is the demo from the forum topic, and the dxf is exported from it with the above version of FreeCAD | ||||
| Tags | DXF | ||||
I made a patch, that solved the problem for me with the demo-file. Question, is the projection direction for this problem always the z-axis? If not the patch has to be modified, in order to work also for other projection directions. Ulrich |
Indeed the dxf exporter must work with different projections (there is a setting in Draft preferences to export in the drection of the current view) |
| 2014-04-18 02:03 | jmaustpc | New Issue | |
| 2014-04-18 02:03 | jmaustpc | Status | new => assigned |
| 2014-04-18 02:03 | jmaustpc | Assigned To | => yorik |
| 2014-04-18 02:03 | jmaustpc | File Added: FlippedArc.fcstd | |
| 2014-04-18 02:04 | jmaustpc | Tag Attached: DXF | |
| 2014-04-18 02:06 | jmaustpc | File Added: flippedornot.dxf | |
| 2014-04-18 19:45 | ulrich1a | File Added: 0002-patch-for-flipped-arcs-in-DXF-export.patch.zip | |
| 2014-04-18 19:48 | ulrich1a | Note Added: 0004569 | |
| 2014-04-18 19:54 | yorik | Note Added: 0004570 | |
| 2014-05-03 15:49 | yorik | Project | FreeCAD => Draft |
| 2014-05-03 15:49 | yorik | Product Version | trunk => |
| 2014-05-03 15:49 | yorik | Target Version | trunk => 0.14 |
| 2014-05-08 15:58 | yorik | Changeset attached | => FreeCAD Master master 9cd2c750 |
| 2014-05-08 15:58 | yorik | Status | assigned => closed |
| 2014-05-08 15:58 | yorik | Resolution | open => fixed |
| 2014-06-23 18:45 | yorik | Relationship added | related to 0001590 |
