| 0001590 | Draft | Bug | public | 2014-06-23 13:17 | 2014-08-28 17:02 |
| Reporter | rolbit | Assigned To | yorik | ||
| Summary | 0001590: arcs in dxf are reversed | ||||
| Description | The filets on some parts are getting reversed when exported as dxf. seems to happen only when using mirror. Looks similar to bug 1513 but the test file provided there works perfectly | ||||
| Steps To Reproduce | see attached files | ||||
| Additional Information | OS: Ubuntu 14.04 LTS Word size: 64-bit Version: 0.14.3677 (Git) Branch: master Hash: 07c64e206d05ae662ba40ae125ba991cced7cc9e Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.7.0 | ||||
Always problems with these DXF arcs... I'll look at it. |
As a temporary workaround if anybody needs correct DXF file export before Yorik fixes flipped arcs behaviour Draft Shape2DView tool can be used: http://www.freecadweb.org/wiki/index.php?title=Draft_Shape2DView But it is important Shape2DView result is converted to sketch with Draft Draft2Sketch tool. As i said in my original bug report it looks like sketcher fillets/arcs are not affected. http://www.freecadweb.org/wiki/index.php?title=Draft_Draft2Sketch |
FreeCAD: master 16ede0e5 2014-08-28 18:32:45 Details Diff |
Draft: fixes in DXF exporter - fixes 0001590, 0001653 * Fixed arc directions * Turned max spline segment length preference option into a float * Fixed ellipses export |
Affected Issues 0001590, 0001653 |
| mod - src/Mod/Draft/Draft_rc.py | Diff File | ||
| mod - src/Mod/Draft/Resources/ui/userprefs-import1.ui | Diff File | ||
| 2014-06-23 13:17 | rolbit | New Issue | |
| 2014-06-23 13:17 | rolbit | File Added: test.zip | |
| 2014-06-23 18:44 | yorik | Assigned To | => yorik |
| 2014-06-23 18:44 | yorik | Status | new => assigned |
| 2014-06-23 18:45 | yorik | Relationship added | related to 0001513 |
| 2014-06-23 18:45 | yorik | Note Added: 0004767 | |
| 2014-07-06 15:10 | yorik | Project | FreeCAD => Draft |
| 2014-07-06 15:26 | yorik | Target Version | => 0.15 |
| 2014-07-30 22:08 | yorik | Relationship added | has duplicate 0001653 |
| 2014-07-31 02:17 | triplus | Note Added: 0004899 | |
| 2014-07-31 02:18 | triplus | Note Edited: 0004899 | |
| 2014-07-31 02:19 | triplus | Note Edited: 0004899 | |
| 2014-08-28 17:02 | yorik | Changeset attached | => FreeCAD Master master 16ede0e5 |
| 2014-08-28 17:02 | yorik | Status | assigned => closed |
| 2014-08-28 17:02 | yorik | Resolution | open => fixed |
