| 0001516 | PartDesign | Bug | public | 2014-04-26 16:17 | 2017-01-31 17:51 |
| Reporter | tempr | Assigned To | |||
| Platform | PC | OS | Windows 7 Ultimate | OS Version | SP 1 |
| Summary | 0001516: Problem with refreshing geometry on Groove | ||||
| Description | When I moved the Groove feature sketch points around they sometimes got stuck and the Groove feature didn't reflect the current sketch state. Problem seemed to occur only when snap was turned on, regardless of where the point was moved, inside or outside the "snap areas". Described in detail with pictures here (search for this text to get to information about this bug, read from that point): "As promised - here is that other bug" http://forum.freecadweb.org/viewtopic.php?f=19&t=6394 | ||||
| Steps To Reproduce | 1. Open the attached file 2. Edit the Groove feature sketch 3. Try to move one of the sketch points around 4. At some point the Groove feature should stop refreshing the change in the sketch and the point will get stuck (can be "un-stucked" by selecting it first and then moving it or moving some other point in the sketch) | ||||
| Additional Information | My FreeCAD build info: OS: Windows 7 Platform: 32-bit Version: 0.14.3389 Python version: 2.6.2 Qt version: 4.5.2 Coin version: 3.1.0 SoQt version: 1.4.1 OCC version: 6.5.1 | ||||
I have also tried it on this unofficial build with same results (bug): OS: Windows 7 Platform: 32-bit Version: 0.14.3343 (Git) Branch: libpack Hash: 8dcb8f68cf17ef152d34d226d7699c98c5bb59fb Python version: 2.7.6 Qt version: 4.8.5 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.7.0 |
Can't reproduce OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4451 (Git) Branch: master Hash: 3210d0d2a003618a1aee598904884ac262c35f39 Python version: 2.7.6 Qt version: 4.8.5 Coin version: 4.0.0a OCC version: 6.6.0 |
Labeled #tobeclosed but needs to be confirmed beforehand. |
An "Update view" option was added since this bug was reported, it needs to be checked for the Groove feature to update automatically (as well as the Groove's visibility set active while Revolution being hidden). I can't reproduce the issue either on the current 0.16.6707 release. OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6707 (Git) Build type: None Branch: releases/FreeCAD-0-16 Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
Resolving as attempts to reproduce didn't produce + forum screenshots are 404 |
| 2014-04-26 16:17 | tempr | New Issue | |
| 2014-04-26 16:17 | tempr | File Added: groovetest.FCStd | |
| 2014-04-26 16:19 | tempr | Note Added: 0004575 | |
| 2015-01-12 23:11 | wmayer | Note Added: 0005645 | |
| 2017-01-12 23:59 | Kunda1 | Tag Attached: #tobeclosed | |
| 2017-01-12 23:59 | Kunda1 | Note Added: 0007695 | |
| 2017-01-14 19:30 | normandc | Note Added: 0007768 | |
| 2017-01-14 20:26 | Kunda1 | Note Added: 0007770 | |
| 2017-01-14 20:26 | Kunda1 | Status | new => resolved |
| 2017-01-14 20:26 | Kunda1 | Resolution | open => unable to reproduce |
| 2017-01-14 20:26 | Kunda1 | Assigned To | => Kunda1 |
| 2017-01-14 20:26 | Kunda1 | Assigned To | Kunda1 => |
| 2017-01-14 20:26 | Kunda1 | Tag Detached: #tobeclosed | |
| 2017-01-31 17:51 | wmayer | Status | resolved => closed |
