0001533FreeCADBugpublic2015-01-02 22:12
ReporterCABrouwers Assigned To
PlatformWintelOSWin 7 ProOS VersionWin 7 Pro
Product Version0.13
Fixed in Version0.13
Summary0001533: Sketch report conflict with deleted contraint
DescriptionI have added and then remove constraints to a sketch. The task panels shows a conflict between constraints but one of the constraints listed doesn't appear in the constraints list. I an not sire if the problem is that the constraints is missing in the list or that the freeCAD sees a conflict with a deleted constraints . I believe the later but i don't remember my steps.
Steps To ReproduceLoad the attached sketch. A conflict is indicated between constraints 11, 17 and 19 however constraint 17 does not exist.
CABrouwers
2014-05-05 02:28
reporter
Holder.FCStd (Attachment missing)
CABrouwers
2014-05-05 13:16
reporter   ~0004625
I ran into the same issue with another draft and believe that the problem might arise when adding a explicit point coincidence constraint. This kind of constraint does not appear in the constraint list but can appear in a conflict.
microelly2
2014-05-05 14:59
reporter   ~0004626
It's not a bug:
Switch the Filter in the constraints subwindow from normal to all
then you can see all constraints, 0000017 appears too.
2014-05-20 17:35
administrator   ~0004708
It's definitely not a major issue. Maybe the error panel should state that the filter should be set to "All" to see all constraints.
CABrouwers
2014-05-20 20:36
reporter   ~0004712
Thanks for following. I didn't notice the filter.
2014-05-05 02:28 CABrouwers New Issue
2014-05-05 02:28 CABrouwers File Added: Holder.FCStd
2014-05-05 13:16 CABrouwers Note Added: 0004625
2014-05-05 14:59 microelly2 Note Added: 0004626
2014-05-20 17:35 wmayer Note Added: 0004708
2014-05-20 17:35 wmayer Severity major => minor
2014-05-20 20:36 CABrouwers Note Added: 0004712
2015-01-02 22:12 wmayer Status new => closed
2015-01-02 22:12 wmayer Resolution open => no change required
2015-01-02 22:12 wmayer Fixed in Version => 0.13
