| 0000017 | FreeCAD | Feature | public | 2009-09-28 15:41 | 2017-09-14 13:46 |
| Summary | 0000017: Support of more basic elements | ||||
| Description | I think, it would be good to support more basis elements, and basis functionalities which are usefull for more than one application. Elements: - axis systems (interesting for CAM, Measuring, ...) - point and plane (cutting, ...) Functionality: - (show/noshow) show all invisible elements, an select the elements to change them to visible - (selection of elements) by fence, by box, ... I think, some of these functions should appear in the basic system, to be used from every application. | ||||
| duplicate of | 0000328 | closed | Support of more basic elements |
I think I will at least do the plane and coordinate system |
Would be cool... Take a look at the Draft's working plane that Ken Cline made, I found it pretty cool to use. Doesn't bother you when you don't need it, but it's there when you need... Basically it is just a plane, that has axis, u and v vectors (local x,y,z) and a position. You can define it anytime, or "release" it. If it is defined, everything you do (draw, transform, etc) "sticks" to it, otherwise not. Pretty easy. Select by box would be pretty useful too... |
Original link: https://sourceforge.net/tracker/?func=detail&aid=1818040&group_id=49159&atid=455301 |
I fear have to wait for 0.12 |
| 2009-09-28 15:41 |
New Issue | |
| 2009-09-28 15:48 |
Status | new => assigned |
| 2009-09-28 15:48 |
Assigned To | => Jriegel |
| 2010-06-29 13:59 |
Note Added: 0000255 | |
| 2010-06-29 13:59 |
Target Version | => 0.11 |
| 2010-06-29 13:59 |
Description Updated | |
| 2010-07-02 17:34 | yorik | Note Added: 0000258 | |
| 2010-08-18 10:08 | wmayer | Note Added: 0000300 | |
| 2011-01-13 14:59 |
Note Added: 0000514 | |
| 2011-01-13 14:59 |
Target Version | 0.11 => 0.12 |
| 2011-01-13 14:59 |
| 2011-09-16 04:59 |
Target Version | 0.12 => 0.13 |
| 2012-02-29 11:04 | wmayer | Relationship added | duplicate of 0000328 |
| 2012-11-13 20:25 |
Target Version | 0.13 => 0.14 |
| 2014-06-25 12:08 | wmayer | Target Version | 0.14 => 0.15 |
| 2015-01-25 15:43 | yorik | Target Version | 0.15 => |
| 2017-09-14 13:46 | wmayer | Status | assigned => closed |
| 2017-09-14 13:46 | wmayer | Resolution | open => fixed |
| 2017-09-14 13:46 | wmayer | Fixed in Version | => 0.17 |
