| 0001545 | FreeCAD | Bug | public | 2014-05-14 16:09 | 2015-01-24 22:48 |
| Reporter | fooons | Assigned To | |||
| Platform | 64-bit | OS | Ubuntu | OS Version | 14.04 LTS |
| Summary | 0001545: Folders with tick in the name cannot be opened | ||||
| Description | When I want to explore content in a folder wich have tick in the name appears greyed and can't access the content. Folder Imágenes, Música, Vídeos appears as Imgenes,Msica,Vdeos | ||||
| Steps To Reproduce | 1. Open file 2. Select from tree a tick named folder | ||||
| Additional Information | This problem appears in Spanish language | ||||
That's not a FreeCAD bug. It's a bug in the system file dialog. What desktop environment do you use? |
When Qt determines the storage path of e.g. QDesktopServices::storageLocation(QDesktopServices::DesktopLocation) then it reads in the file user-dirs.dirs which usually is under $HOME/.config or where the environment variable XDG_CONFIG_HOME points to. See also http://www.freedesktop.org/wiki/Software/xdg-user-dirs So, the user-dirs.dirs file contains the correctly translated text but because in the main() function "putenv("LANG=C");" is used to fix an OCC bug Qt fails to read in any non-ASCII characters. This leads to a path which doesn't exist and that's why the item is greyed out. |
| 2014-05-14 16:09 | fooons | New Issue | |
| 2014-05-14 16:14 | fooons | File Added: Captura de pantalla de 2014-05-14 18:01:00.png | |
| 2014-05-14 16:16 | wmayer | Relationship added | has duplicate 0001546 |
| 2014-12-03 21:40 | wmayer | Note Added: 0005352 | |
| 2015-01-07 11:38 | wmayer | Relationship deleted | has duplicate 0001546 |
| 2015-01-07 11:38 | wmayer | Relationship added | related to 0001852 |
| 2015-01-07 11:45 | wmayer | Note Added: 0005546 | |
| 2015-01-07 14:38 | wmayer | Note Edited: 0005546 | |
| 2015-01-24 22:47 | wmayer | Changeset attached | => FreeCAD Master master f32caef4 |
| 2015-01-24 22:48 | wmayer | Status | new => closed |
| 2015-01-24 22:48 | wmayer | Resolution | open => fixed |
| 2015-01-24 22:48 | wmayer | Fixed in Version | => 0.15 |
