0001852FreeCADBugpublic2017-02-10 10:50
Reportershoogen Assigned Toshoogen
Status closedResolutionfixed
OSPOSIX
Product Version0.15
Target Version0.15
Summary0001852: The python interpreter does not recognize the posix locale settings
DescriptionThis currently breaks the usage of non-ascii characters in filenames for import and export handled in python modules.
Steps To Reproduce$ python -c "import sys;print sys.getfilesystemencoding()"
UTF-8
$ LANG=C python -c "import sys;print sys.getfilesystemencoding()"
ANSI_X3.4-1968
$ ./fc-build/bin/FreeCADCmd
[FreeCAD Console mode <Use Ctrl-D (i.e. EOF) to exit.>]
>>> import sys
'ANSI_X3.4-1968'
>>> import locale
>>> locale.getdefaultlocale()
(None, None)
Tagsencoding, locale, sys.getfilesystemencoding, unicode
Relationships
related to 0002891 closedwmayer Sketcher Sketching impossible, Type.Error Exception
related to 0001545 closed FreeCAD Folders with tick in the name cannot be opened
related to 0002018 closedwmayer FreeCAD Running Freecad with specific locale causes freeze
child of 0001027 closedshoogen FreeCAD UTF-8 encoded PyString objects are used instead of unicode objects to pass unicode data to the python interpreter
child of 0001930 closedshoogen Drawing Export a page to an SVG file and UnicodeEncodeError
shoogen
2014-12-08 14:01
developer   ~0005360
http://www.mevislab.de/docs/current/MeVis/ThirdParty/Documentation/Publish/Python/library/locale.html
> When Python code uses the locale module to change the locale, this also affects the embedding application. If the embedding application doesn’t want this to happen, it should remove the _locale extension module (which does all the work) from the table of built-in modules in the config.c file, and make sure that the _locale module is not accessible as a shared library.
Great idea python ;)
shoogen
2014-12-09 16:21
developer   ~0005361
https://github.com/5263/FreeCAD/commit/c85ddd166ef80e747719549922bb7e5ddffc58cd
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=559846
shoogen
2014-12-09 16:37
developer   ~0005362
Werner, could you please comment on the following patch
https://github.com/5263/FreeCAD/compare/dev-locale
diff --git a/src/Main/MainCmd.cpp b/src/Main/MainCmd.cpp
index 17cb6c1..b7c1d68 100644
--- a/src/Main/MainCmd.cpp
+++ b/src/Main/MainCmd.cpp
@@ -70,4 +70 @@ int main( int argc, char ** argv )
-#if defined(FC_OS_LINUX)
- putenv("LANG=C");
- putenv("LC_ALL=C");
-#else
+ setlocale(LC_ALL, "");
@@ -75 +71,0 @@ int main( int argc, char ** argv )
-#endif
diff --git a/src/Main/MainGui.cpp b/src/Main/MainGui.cpp
index 300084a..a0050c7 100644
--- a/src/Main/MainGui.cpp
+++ b/src/Main/MainGui.cpp
@@ -194,2 +194 @@ int main( int argc, char ** argv )
- putenv("LANG=C");
+ putenv("LC_NUMERIC=C");
@@ -199,2 +198 @@ int main( int argc, char ** argv )
- putenv("LANG=C");
shoogen
2014-12-09 19:38
developer   ~0005363
It seems OCCT fixed the problem in version 6.6.0
http://tracker.dev.opencascade.org/view.php?id=22898
2014-12-11 10:54
administrator   ~0005365
I can confirm that "putenv("LC_NUMERIC=C");" is sufficient now to fix the OCC problem -- tested with OCC 6.7.1
shoogen
2014-12-15 10:03
developer   ~0005385
I see two possibilities.
1. Don't touch the locales before the 0.15 release
this will require a different workaround for different platforms.
2. Do tackle this problem before the 0.15 release.
this requires testing on all platforms before the release.
Thank you Werner for testing.
I don't understand why to use putenv (instead of setlocale) on linux. It would make sense on windows, because windows has no fork command.
If putenv is nessesary because of a setlocale used somewhere is (in QT for example) and if other parts of FreeCAD rely on LC_NUMERIC=C (like the xml writer and parser) then, my patch would be a bad idea.
However, the xml output seems to unaffected.
2014-12-15 10:48
administrator   ~0005386
I go for possibility 1) as it's too dangerous to do this change for an imminent release.
Thinking further about why putenv works but setlocale fails I think putenv affects the locale settings for C and C++ while setlocale affects it only for C.
The C++ way to change the locale is to do:
std::locale::global(std::locale("C"))
but it should be checked if there is a way to change only numeric input/output
Here we explicitly change the locale settings of a concrete stream instance. Search for "imbue" in the sources.
2014-12-15 11:05
administrator   ~0005387
Maybe just writing
std::locale::global(std::locale("C", std::locale::numeric));
does the trick.
See also:
http://stackoverflow.com/questions/12373341/does-stdlocaleglobal-make-affect-to-printf-function
shoogen
2014-12-16 19:04
developer   ~0005396
git://github.com/5263/FreeCAD dev-locale-cpp
std::locale::global(std::locale(std::locale(""),std::locale("C"),std::locale::numeric));
seems to set the locale correctly (on linux).
On my system it has the "name"
LC_CTYPE=de_DE.UTF-8;LC_NUMERIC=C;LC_TIME=de_DE.UTF-8;LC_COLLATE=de_DE.UTF-8;LC_MONETARY=de_DE.UTF-8;LC_MESSAGES=de_DE.UTF-8;LC_PAPER=de_DE.UTF-8;LC_NAME=de_DE.UTF-8;LC_ADDRESS=de_DE.UTF-8;LC_TELEPHONE=de_DE.UTF-8;LC_MEASUREMENT=de_DE.UTF-8;LC_IDENTIFICATION=de_DE.UTF-8
and having a name allows to set the C locale as well.
shoogen
2014-12-16 21:08
developer   ~0005399
$ git grep -l strtod
src/3rdParty/CxImage/png/CHANGES
src/3rdParty/CxImage/png/pngrutil.c
src/3rdParty/salomesmesh/src/SMESH/SMESH_Pattern.cpp
$ git grep -l atof
src/3rdParty/CxImage/png/libpng-1.2.24.txt
src/3rdParty/salomesmesh/inc/UNV_Utilities.hxx
src/Base/Parameter.cpp
src/Base/Quantity.cpp
src/Base/Reader.cpp
src/Mod/Cam/App/ConvertDyna.cpp
src/Mod/Fem/App/AppFemPy.cpp
src/Mod/Fem/App/FemMesh.cpp
src/Mod/Mesh/App/Core/MeshIO.cpp
src/Mod/Points/App/PointsAlgos.cpp
src/Mod/Robot/App/Robot6Axis.cpp
$ git grep -l imbue
src/Base/Reader.cpp
src/Base/Writer.cpp
Hm, I'm not amused.
shoogen
2014-12-17 18:17
developer   ~0005401
with the latest change i can't open exiting documents. ;(
shoogen
2014-12-17 19:13
developer   ~0005402
Qt ;(
2014-12-17 19:41
administrator   ~0005403
Which change?
shoogen
2014-12-17 19:51
developer   ~0005404
mine git://github.com/5263/FreeCAD dev-locale-cpp
http://www.qtcentre.org/threads/53127-Override-locale-with-QSystemLocale
shoogen
2014-12-18 07:00
developer   ~0005405
Ok, now i understand the need for the putenv on unixoid OSes.
The damn Qt uses qgetenv to setup the locale.
https://qt.gitorious.org/qt/qtbase/source/e0a8b5ce88bc50440dcec2fe3a86d83e2a7dc7b0:src/corelib/tools/qlocale_unix.cpp#L69
shoogen
2014-12-21 12:08
developer   ~0005414
If you don't want to modify the locale we have to use old method of passing utf8 byte strings in the 0.15 release (at least for unixoid platforms)
git://github.com/5263/FreeCAD ugly_workaround_for_bug_1852
2014-12-21 12:28
administrator   ~0005415
I haven't checked yet the branch dev-locale-cpp. Does this fix the issue reliably?
When I said that I would postpone the fix for 0.16 then I meant to leave bug in for 0.15. But since you want to have a solution already for 0.15 then I think it's better to apply the proper solution instead of reverting any commits because this needs a lot of testing anyway and is as your branch name says really "ugly".
shoogen
2014-12-21 16:52
developer   ~0005420
I updated dev-locale-cpp
I looked promissing for normal spinboxes. But I got problems with quantity spinboxes. These persisted when i did an icremental build with the version of the master branch. (I'm waiting for a clean build of master before i continue testing)
And finally I have to use the proper namespace in c++ ;)
2014-12-21 17:17
administrator   ~0005422
Write this:
class AppExport DecimalSystemLocale : public QSystemLocale
IMO, in case this class is needed it would make more sense to move this to "Base". In this case the export macro must be "BaseExport".
shoogen
2014-12-21 17:44
developer   ~0005423
To me it seems that the locale works in QT, but now the Quantity Parser is broken.
2014-12-21 18:19
administrator   ~0005424
One thing I still do not understand is why something for Qt needs to be fixed.
The story is:
1. All the trouble started because OCC doesn't handle numeric input properly.
2. That's why setting LANG and LC_ALL to C solved this issue.
3. Since this affects Qt "QLocale::system();" is called very first to set up the locale stuff for Qt and QFile::setEncodingFunction/QFile::setDecodingFunction is used to utf-8 handling
4. However, setting LC_ALL and LANG affects Python and since OCC now improved the handling for numeric input setting LC_NUMERIC seems to be sufficient.
Now, does changing LC_NUMERIC affect Qt in a certain way?
Btw, for MacOSX nothing needs to be done because with current master "import sys;print sys.getfilesystemencoding()" returns UTF-8 and applying the dev-locale-cpp branch makes the applicationcrash immediately.
shoogen
2014-12-21 18:50
developer   ~0005425
Qt has the ability to set the deflection Property to 0 when loading an existing FreeCAD file with an unexpected decimal seperator. And OCCT starts mesheshing with 0 deflection. ;)
1. That should be fixed by 6.6.0
2. That did not prevent Jürgen from using atof in the QuantityParser.
3. That made sense for Qt < 4.2. But I would consider this as not beautiful. And using a different locale in Qt, c++ and the python interpreter is messy. When I'm touching the code anyway I try, to make it more beautiful. If that's not possible we have to live with that. But Qt allows to set the decimal seperator independenly.
4. I agree for Linux. But I don't think Qt will respect it on windows.
shoogen
2014-12-21 19:07
developer   ~0005426
It seems that std::locale::global(std::locale(std::locale(""),std::locale("C"), std::locale::numeric));
is not enough for the atof() in src/Base/Quantity.cpp to accept a '.' as decimal seperator on linux with my locale
shoogen
2014-12-21 20:07
developer   ~0005428
neither is a std::setlocale()
2014-12-21 20:49
administrator   ~0005429
How do you get a FreeCAD project with an unexpected decimal separator (i.e. another one than ".")?
If this causes any trouble we can easily use C++ streams instead. There you can set on a single instance (not globally) use the C locale.
I disagree. For low-level handling (e.g file reading, writing, ...) I would like to use a locale that is platform independent, i.e. the "C" locale.
For user input in the GUI (i.e. Qt) I would like to use the system locale because it would be extremely annoying when in another application I use the system locale and suddenly in FreeCAD it would be the C locale.
shoogen
2014-12-21 23:01
developer   ~0005430
I haven't so far i only opened documents when qt expected a comma.
Yes, i have done it for the quantity parser in my branch. But atof is also used in third party libs like CxImage.
I partly agree. It would make sense if we devide the functionalty beetween frontend and backend. But we can't draw the line between c, c++, qt and python. We use qstrings in the properties handling and python to interface fileformats and gui.
Thats a good idea. But this means that you would need to use a locale object when handling properties.
shoogen
2015-01-24 18:32
developer   ~0005714
Ok, its been an interesting but disappointing excursus. Lets just use putenv in the manner it is currently used, but for LC_NUMMERIC. Thus making the minimal possible change.
I filed a pull-request. (without the unit test, because it won't test the behavior correctly on windows)
2017-02-10 10:18
administrator   ~0008261
This explains all the trouble we had related to locales: https://forum.freecad.org/viewtopic.php?f=3&t=20537#p158962
So, it's caused by Qt by calling setlocale(LC_ALL,"") which then applies the system-wide locale settings. So, on systems which set LC_ALL (e.g. Debian) this leads to problems especially if the decimal separator is a comma.
I played a bit with that and made the observation that the decimal separator of floating point numbers in the user.cfg will become a comma and then it can happen that the next time it cannot handle the conversion from text to float and sets it to 0.0.
Especially for the tessellation of shapes this leads to massive problems because then the deviation is 0.0 instead of a sensible value and causes the tessellation of curved shapes to take forever.
Related Changesets
FreeCAD: master f32caef4
2014-12-09 17:24:34
shoogen
Details Diff
respect locale environment except for LC_NUMERIC
fixes 0001852
Affected Issues
0001545, 0001852
mod - src/Main/MainCmd.cpp Diff File
mod - src/Main/MainGui.cpp Diff File
2014-12-08 13:46 shoogen New Issue
2014-12-08 13:48 shoogen Steps to Reproduce Updated
2014-12-08 13:49 shoogen Steps to Reproduce Updated
2014-12-08 14:01 shoogen Note Added: 0005360
2014-12-08 14:02 shoogen Note Edited: 0005360
2014-12-08 14:04 shoogen OS Linux => POSIX
2014-12-08 14:04 shoogen Summary The python interpreter does not recognize the locale settings => The python interpreter does not recognize the posix locale settings
2014-12-08 14:22 shoogen Tag Attached: sys.getfilesystemencoding
2014-12-08 14:22 shoogen Tag Attached: unicode
2014-12-08 14:23 shoogen Tag Attached: encoding
2014-12-09 16:21 shoogen Note Added: 0005361
2014-12-09 16:22 shoogen Note Edited: 0005361
2014-12-09 16:37 shoogen Note Added: 0005362
2014-12-09 16:37 shoogen Assigned To => wmayer
2014-12-09 16:37 shoogen Status new => assigned
2014-12-09 19:38 shoogen Note Added: 0005363
2014-12-09 19:38 shoogen Note Edited: 0005363
2014-12-11 10:54 wmayer Note Added: 0005365
2014-12-15 10:03 shoogen Note Added: 0005385
2014-12-15 10:48 wmayer Note Added: 0005386
2014-12-15 11:05 wmayer Note Added: 0005387
2014-12-16 13:34 shoogen Relationship added child of 0001027
2014-12-16 19:04 shoogen Note Added: 0005396
2014-12-16 19:04 shoogen Note Edited: 0005396
2014-12-16 21:05 shoogen Note Edited: 0005396
2014-12-16 21:08 shoogen Note Added: 0005399
2014-12-17 18:17 shoogen Note Added: 0005401
2014-12-17 19:13 shoogen Note Added: 0005402
2014-12-17 19:31 shoogen Note Edited: 0005402
2014-12-17 19:41 wmayer Note Added: 0005403
2014-12-17 19:51 shoogen Note Added: 0005404
2014-12-18 07:00 shoogen Note Added: 0005405
2014-12-21 12:08 shoogen Note Added: 0005414
2014-12-21 12:28 wmayer Note Added: 0005415
2014-12-21 16:52 shoogen Note Added: 0005420
2014-12-21 17:17 wmayer Note Added: 0005422
2014-12-21 17:44 shoogen Note Added: 0005423
2014-12-21 18:19 wmayer Note Added: 0005424
2014-12-21 18:50 shoogen Note Added: 0005425
2014-12-21 19:07 shoogen Note Added: 0005426
2014-12-21 20:07 shoogen Note Added: 0005428
2014-12-21 20:49 wmayer Note Added: 0005429
2014-12-21 23:01 shoogen Note Added: 0005430
2015-01-07 11:38 wmayer Relationship added related to 0001545
2015-01-24 10:17 shoogen Relationship added child of 0001930
2015-01-24 18:32 shoogen Note Added: 0005714
2015-01-24 19:01 shoogen Note Edited: 0005714
2015-01-24 22:39 shoogen Changeset attached => FreeCAD Master master f32caef4
2015-01-24 22:39 shoogen Assigned To wmayer => shoogen
2015-01-24 22:39 shoogen Status assigned => closed
2015-01-24 22:39 shoogen Resolution open => fixed
2015-03-21 23:50 shoogen Relationship added related to 0002018
2017-02-10 10:04 wmayer Relationship added related to 0002891
2017-02-10 10:18 wmayer Note Added: 0008261
2017-02-10 10:50 Kunda1 Tag Attached: locale
