| 0001557 | GCS | General | public | 2014-05-19 09:55 | 2018-06-03 07:58 |
| Reporter | ulrich1a | Assigned To | abdullah | ||
| Summary | 0001557: Sketcher symmetric constraint does not report redundant constraints | ||||
| Description | The symmetric constraint fails to report redundant constraints. This may give sketches with redundant constraints, which have problems later. For example sketches with several degrees of freedom do not move. Examples can be found here: http://forum.freecadweb.org/viewtopic.php?f=8&t=6617#p53589 and here: http://forum.freecadweb.org/viewtopic.php?f=3&t=6424#p51775 It is the file Three_divisions_test_symmetry_solution_problem.fcstd | ||||
| Steps To Reproduce | 1. Make a polyline with two straight lines. 2. Add an equality constraint to the two lines. 3. Add an parallel constraint to the two lines. 4. Add an symmetric constraint between the end points of the polyline and the center point of the polyline. This gives a sketch where the equality as well as the parallel constraints are redundant to the symmetric constraint. The object can not be moved any more. | ||||
| Tags | constraints, Solver | ||||
Another example of how to reproduce is here: http://forum.freecadweb.org/viewtopic.php?f=10&t=7441#p60608 Related forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=7456&start=10#p60669 |
bumped forum thread |
Bejant replied in https://forum.freecadweb.org/viewtopic.php?f=10&t=7456&p=156251#p156251 > It should remain open because in recreating the 4 steps Ulrich listed in the ticket the problem still exists. OS: Ubuntu 16.04.1 LTS Word size of OS: 32-bit Word size of FreeCAD: 32-bit Version: 0.17.9796 (Git) Build type: None Branch: master Hash: bebda4c6adcad59c4abe82bcbc8703e90c8e1ceb Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
The solver recognizes the redundant constraint and reports it to as log message but it doesn't report it to the GUI. This is the output in the log: Sketcher::RedundantSolving-DogLeg- Sketcher Redundant solving: 1 redundants Sketcher::setUpSketch()-T:0.001 Sketcher::Solve()-DogLeg-T:0 Sketcher::RedundantSolving-DogLeg- Sketcher Redundant solving: 1 redundants Sketcher::setUpSketch()-T:0 |
Hi there I'm looking to get involved in FreeCAD as a developer and I thought this might be a good issue to start with, would you a agree? If there are no objections, I'd give it a go. Any help, tips and/or contacts would of course be greatly appreciated. :) Regards, Damian |
@wohlklang please connect to the the devs via the forum thread associated with this ticket to get the orientation that you're seeking |
https://github.com/FreeCAD/FreeCAD/commit/03c3539dbfac10e38abc5f7fec8fefb8966d388e |
Following the instructions I cannot see that this issue is fixed => reopening |
https://github.com/FreeCAD/FreeCAD/pull/1429 |
| 2014-05-19 09:55 | ulrich1a | New Issue | |
| 2014-08-28 14:21 | bejant | Note Added: 0005019 | |
| 2017-01-26 21:14 | Kunda1 | Note Added: 0007998 | |
| 2017-01-26 21:14 | Kunda1 | Tag Attached: #pending | |
| 2017-01-27 04:05 | Kunda1 | Note Added: 0008018 | |
| 2017-01-27 04:05 | Kunda1 | Tag Detached: #pending | |
| 2017-01-27 04:06 | Kunda1 | Status | new => confirmed |
| 2017-09-24 14:41 | wmayer | Note Added: 0010169 | |
| 2017-09-27 12:13 | Kunda1 | Tag Attached: constraints | |
| 2017-09-27 12:13 | Kunda1 | Tag Attached: Solver | |
| 2017-10-29 21:51 | wohlklang | Note Added: 0010365 | |
| 2017-10-31 09:04 | Kunda1 | Note Added: 0010368 | |
| 2017-10-31 20:38 | Kunda1 | Project | FreeCAD => Sketcher |
| 2018-04-17 08:04 | abdullah | Assigned To | => abdullah |
| 2018-04-17 08:04 | abdullah | Status | confirmed => assigned |
| 2018-05-31 11:56 | wmayer | Status | assigned => closed |
| 2018-05-31 11:56 | wmayer | Resolution | open => fixed |
| 2018-05-31 11:56 | wmayer | Note Added: 0011326 | |
| 2018-05-31 12:23 | wmayer | Status | closed => confirmed |
| 2018-05-31 12:23 | wmayer | Resolution | fixed => open |
| 2018-05-31 12:23 | wmayer | Category | Bug => General |
| 2018-05-31 12:23 | wmayer | Note Added: 0011330 | |
| 2018-06-03 07:58 | chrisb | Status | confirmed => closed |
| 2018-06-03 07:58 | chrisb | Resolution | open => fixed |
| 2018-06-03 07:58 | chrisb | Note Added: 0011346 |
