| 0001592 | File formats | Feature | public | 2014-06-28 07:10 | 2016-02-14 21:47 |
| Reporter | shoogen | Assigned To | wmayer | ||
| Priority | low | Severity | feature | Reproducibility | N/A |
| Summary | 0001592: Import colored PCL point clouds | ||||
| Description | If PCL is present, it should be used to read and write the PCL file format. | ||||
What do you mean with "PCL"? This http://pointclouds.org/documentation/tutorials/pcd_file_format.php#pcd-file-format ? |
If we already have an interface to the pointcloud lib, we should use it to open COLORED point clouds. Formats would be PLY and PCD |
FreeCAD: master 1a64c3f2 2016-02-14 22:46:27 Details Diff |
+ fixes 0001592: Import colored PCL point clouds |
Affected Issues 0001592 |
| mod - src/Mod/Points/App/AppPointsPy.cpp | Diff File | ||
| mod - src/Mod/Points/App/PointsAlgos.cpp | Diff File | ||
| mod - src/Mod/Points/App/PointsAlgos.h | Diff File | ||
| mod - src/Mod/Points/Init.py | Diff File | ||
| 2014-06-28 07:10 | shoogen | New Issue | |
| 2014-07-05 14:06 | wmayer | Note Added: 0004774 | |
| 2014-07-05 14:08 | wmayer | Note Edited: 0004774 | |
| 2014-09-03 22:15 | shoogen | Note Added: 0005069 | |
| 2015-09-09 22:02 | savio araujo | Issue cloned: 0002252 | |
| 2015-09-10 19:17 | yorik | Relationship added | has duplicate 0002252 |
| 2016-02-14 21:47 | wmayer | Changeset attached | => FreeCAD Master master 1a64c3f2 |
| 2016-02-14 21:47 | wmayer | Assigned To | => wmayer |
| 2016-02-14 21:47 | wmayer | Status | new => closed |
| 2016-02-14 21:47 | wmayer | Resolution | open => fixed |
