| 0002252 | File formats | Feature | public | 2015-09-09 22:02 | 2015-09-10 19:17 |
| Reporter | savio araujo | Assigned To | yorik | ||
| Priority | low | Severity | feature | Reproducibility | N/A |
| Summary | 0002252: Import colored PCL point clouds | ||||
| Description | If PCL is present, it should be used to read and write the PCL file format. | ||||
What do you mean with "PCL"? This http://pointclouds.org/documentation/tutorials/pcd_file_format.php#pcd-file-format ? |
If we already have an interface to the pointcloud lib, we should use it to open COLORED point clouds. Formats would be PLY and PCD |
Please do not clone issues like that without a reason... It won't make them fixed magically, and only gives us more work. Thanks |
| 2015-09-09 22:02 | savio araujo | New Issue | |
| 2015-09-09 22:02 | savio araujo | Issue generated from: 0001592 | |
| 2015-09-10 19:17 | yorik | Relationship added | duplicate of 0001592 |
| 2015-09-10 19:17 | yorik | Note Added: 0006389 | |
| 2015-09-10 19:17 | yorik | Status | new => closed |
| 2015-09-10 19:17 | yorik | Assigned To | => yorik |
| 2015-09-10 19:17 | yorik | Resolution | open => duplicate |
