| 0001612 | Draft | Bug | public | 2014-07-14 15:08 | 2016-11-08 17:29 |
| Summary | 0001612: Projecting arcs to SVG gives wrong results under certain angles | ||||
| Description | Some arcs get a wrong SVG representation when projected with a specific angle. | ||||
| Additional Information | http://forum.freecad.org/viewtopic.php?f=3&t=7011 | ||||
| Tags | OCC Bug | ||||
The attached file (taken from the linked forum thread) shows the problem |
The problem is basically that projected arcs shouldn't be arcs anymore, but ellipses. But while the OCC bug that prevents projecting shapes without faces is there, it will be hard to solve this bug. Maybe OCC 6.8 fixes the projection bug, I haven't tested yet. In any case, this is probably for after 0.15 release. |
What we might should implement, is the degeneration of a projected circle (or arc) to lines. (If the arc axis has no component in the z direction). The projection bug in OCCT is scheduled for version 7.1.0 |
Good idea, that would already solve many cases. And it's basically just a matter of checking if the angle between the projection vector and the circle's axis = 90°... |
FreeCAD: master 64a7b9e1 2016-11-02 20:06:48 Details Diff |
Draft: Better method to project arcs to SVG - issue 0001612 |
Affected Issues 0001612 |
FreeCAD: master 00b5dbfa 2016-11-08 18:28:33 Details Diff |
Draft: Discretize projected arcs and ellipses - fixes 0001612 |
| mod - src/Mod/Draft/Resources/ui/preferences-svg.ui | Diff File | ||
| 2014-07-14 15:08 | yorik | New Issue | |
| 2014-07-14 15:08 | yorik | Status | new => assigned |
| 2014-07-14 15:08 | yorik | Assigned To | => yorik |
| 2014-07-14 15:08 | yorik | File Added: Test.FCStd | |
| 2014-07-14 15:09 | yorik | Note Added: 0004791 | |
| 2014-07-14 15:09 | yorik | Project | FreeCAD => Draft |
| 2015-01-22 15:53 | yorik | Note Added: 0005687 | |
| 2015-01-22 15:53 | yorik | Target Version | 0.15 => |
| 2015-01-23 10:14 | shoogen | Relationship added | parent of 0001697 |
| 2015-01-23 10:19 | shoogen | Note Added: 0005689 | |
| 2015-01-23 13:06 | yorik | Note Added: 0005690 | |
| 2015-01-28 11:02 | shoogen | Relationship added | related to 0001937 |
| 2015-12-27 16:02 | yorik | Tag Attached: OCC Bug | |
| 2016-01-03 19:17 | yorik | Priority | normal => low |
| 2016-03-22 15:12 | yorik | Summary | Draft - Projecting arcs to SVG gives wrong results under certain angles => Projecting arcs to SVG gives wrong results under certain angles |
| 2016-08-05 13:27 | wandererfan | Relationship added | related to 0002383 |
| 2016-11-02 22:09 | yorik | Changeset attached | => FreeCAD Master master 64a7b9e1 |
| 2016-11-08 17:29 | yorik | Changeset attached | => FreeCAD Master master 00b5dbfa |
| 2016-11-08 17:29 | yorik | Status | assigned => closed |
| 2016-11-08 17:29 | yorik | Resolution | open => fixed |
