| 0002383 | Drawing | Bug | public | 2015-12-30 14:24 | 2017-04-28 12:13 |
| Reporter | yanncad | Assigned To | yorik | ||
| Summary | 0002383: Drawing lines missing or incorrect | ||||
| Description | In drawings created with default options of FreeCAD ("Show hidden lines"=False), - some lines are missing - some lines appear when they should be hidden See attached example. In the attached screenshot, I highlighted in yellow zones where lines are incorrect or missing. I know the drawing workbench is still in dev, but this is my main blocker for a production use of FreeCAD. | ||||
| Steps To Reproduce | 1. create a part with medium complexity (with holes, curved shapes...) 2. make a drawing of it 3. observe the missing lines and/or incorrect lines | ||||
| Additional Information | Keep up the good work with FreeCAD! | ||||
| Tags | OCC 7.1, OCC Bug, upstream | ||||
| related to | 0001612 | closed | yorik | Draft | Projecting arcs to SVG gives wrong results under certain angles |
| related to | 0001697 | closed | yorik | FreeCAD | projection of edges fails |
| related to | 0002730 | closed | yorik | FreeCAD | Fillet are not showed in drawing |
| related to | 0002354 | closed | yorik | Drawing | Arcs missing in projections of revolved sketches |
| child of | 0001931 | closed | wmayer | FreeCAD | migration to OCCT 7.1 |
i have got the same problem. Have you solve the problem? please suggest me |
This is a duplicate of/related to: 0001612 and 0001697. OCC bug report: https://tracker.dev.opencascade.org/view.php?id=25214 The only real fix is to use OCC 7.1 once it is available. Sometimes rotating the part slightly before adding to the drawing helps. Sometimes it doesn't! |
OCC 7.1.0 has been available since Nov 25th 2016 (see https://www.opencascade.com/content/open-cascade-technology-710-available-download) @wmayer seems this ticket is a child of 0001931 |
Reminder sent to: yorik @yorik please test with OCC 7.1 |
Forum thread: https://forum.freecad.org/viewtopic.php?f=10&t=20364 |
Okay the problem is solved in OCC 7.1, all the edges marked on the image above appear correctly, and projecting shapes with no faces works. So I'm closing this issue... |
| 2015-12-30 14:24 | yanncad | New Issue | |
| 2015-12-30 14:24 | yanncad | File Added: bug_drawing.zip | |
| 2016-08-05 09:33 | appbannadee | Note Added: 0007245 | |
| 2016-08-05 09:34 | appbannadee | Note Edited: 0007245 | |
| 2016-08-05 12:36 | wandererfan | Note Added: 0007249 | |
| 2016-08-05 13:26 | wandererfan | Note Edited: 0007249 | |
| 2016-08-05 13:27 | wandererfan | Status | new => feedback |
| 2016-08-05 13:27 | wandererfan | Relationship added | related to 0001612 |
| 2016-08-05 13:28 | wandererfan | Relationship added | related to 0001697 |
| 2016-10-08 13:00 | wandererfan | Relationship added | related to 0002730 |
| 2017-01-09 22:18 | Kunda1 | Tag Attached: OCC Bug | |
| 2017-01-09 22:18 | Kunda1 | Tag Attached: upstream | |
| 2017-01-09 22:22 | Kunda1 | Note Added: 0007589 | |
| 2017-01-11 20:39 | Kunda1 | Relationship added | child of 0001931 |
| 2017-01-14 01:17 | Kunda1 | Relationship added | related to 0002354 |
| 2017-01-27 01:30 | Kunda1 | Tag Attached: OCC 7.1 | |
| 2017-01-27 01:58 | Kunda1 | Note Added: 0008009 | |
| 2017-01-27 01:59 | Kunda1 | Tag Attached: #pending | |
| 2017-01-27 01:59 | Kunda1 | Tag Attached: #tobeclosed | |
| 2017-01-30 13:47 | Kunda1 | File Added: bug_highlight.PNG | |
| 2017-01-30 13:47 | Kunda1 | File Added: part1.FCStd | |
| 2017-01-30 13:47 | Kunda1 | File Deleted: bug_drawing.zip | |
| 2017-01-30 13:47 | Kunda1 | Tag Attached: duplicate | |
| 2017-01-30 13:53 | Kunda1 | Note Added: 0008104 | |
| 2017-01-30 15:19 | yorik | Note Added: 0008106 | |
| 2017-01-30 15:20 | yorik | Status | feedback => closed |
| 2017-01-30 15:20 | yorik | Assigned To | => yorik |
| 2017-01-30 15:20 | yorik | Resolution | open => fixed |
| 2017-01-30 15:20 | yorik | Fixed in Version | => 0.17 |
| 2017-01-30 15:44 | Kunda1 | Tag Detached: #pending | |
| 2017-01-30 15:44 | Kunda1 | Tag Detached: duplicate | |
| 2017-04-28 12:13 | Kunda1 | Tag Detached: #tobeclosed |
