| 0001632 | Sketcher | Feature | public | 2014-07-23 19:33 | 2019-07-30 22:46 |
| Reporter | mghansen256 | Assigned To | abdullah | ||
| Summary | 0001632: Allow entering of diameter instead of radius for circle radius constraint. | ||||
| Description | When adding a radius constraint to a circle, it would be useful to be able to switch to entering the diameter instead of the radius, when the documentation from which I generate the constraints only provides diameters. No more division by 2 in my head ;-) One could simply add a drop-down "radius","diameter" to the dialog box asking for the radius. | ||||
| has duplicate | 0002317 | closed | FreeCAD | diameter vs radius |
Given that you have to enter an odd value as diameter e.g. "22.126 mm" then the workaround is to write "22.126/2 mm" instead. Additionally the diameter constraint can be supported, too. This however will be a new constraint type with is own symbol in the 3d view. Just replacing the current radius input with a diameter input and doing the division by 2 internally might be confusing because in the 3d view something different is shown that the user may not expect. |
I'd like to implement this. I'll try to get a patch submitted in the next day or two. |
@ngallaher ping Still interested in making a patch? |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=29152 |
PR: https://github.com/FreeCAD/FreeCAD/pull/1520 |
https://github.com/FreeCAD/FreeCAD/commit/c84fe5fa3db1bf3758668809bb7c55557e3562a4 |
| 2014-07-23 19:33 | mghansen256 | New Issue | |
| 2014-07-23 21:19 | wmayer | Note Added: 0004842 | |
| 2014-07-25 17:27 | ngallaher | Note Added: 0004858 | |
| 2015-10-31 12:43 | wmayer | Relationship added | has duplicate 0002317 |
| 2017-02-09 21:15 | Kunda1 | Note Added: 0008255 | |
| 2017-02-09 21:16 | Kunda1 | Tag Attached: #lowhangingfruit | |
| 2018-06-06 16:51 | Kunda1 | Note Added: 0011357 | |
| 2018-06-15 14:32 | abdullah | Assigned To | => abdullah |
| 2018-06-15 14:32 | abdullah | Status | new => assigned |
| 2018-06-15 14:32 | abdullah | Note Added: 0011439 | |
| 2018-07-30 10:31 | wmayer | Status | assigned => closed |
| 2018-07-30 10:31 | wmayer | Resolution | open => fixed |
| 2018-07-30 10:31 | wmayer | Fixed in Version | => 0.18 |
| 2018-07-30 10:31 | wmayer | Note Added: 0011565 | |
| 2018-08-26 18:38 | Kunda1 | Tag Detached: #lowhangingfruit | |
| 2019-07-30 22:46 | Kunda1 | Changeset attached | => FreeCAD master c84fe5fa |
