| 0001653 | Draft | Bug | public | 2014-07-30 15:59 | 2014-08-28 17:02 |
| Reporter | triplus | Assigned To | yorik | ||
| Priority | normal | Severity | minor | Reproducibility | random |
| Summary | 0001653: DXF export produces flipped arcs for Fillets | ||||
| Description | Something changed in DXF exporter between September 2013 and July 2014 and it affects fillets (created with Part and Part Design tools). I tested this on part that was successfully exported to DXF (September 2013 daily PPA) and the same part exported in current daily PPA version produces few flipped arcs. If the Fillet is created inside Sketcher arcs are exported as expected. | ||||
| Steps To Reproduce | 1.) Create simple sketch with few connected lines and use Sketcher Fillet Tool to create few fillets and after that use produced sketch to create Pad. Exported DXF file should have correct fillets arcs. 2.) Create simple sketch with just few connected lines and after that use produced sketch to create Pad. Use Part or Part Design Fillet Tool on created Pad to create few fillets on it. Exported DXF file will have few flipped fillets arcs. | ||||
FreeCAD: master 16ede0e5 2014-08-28 18:32:45 Details Diff |
Draft: fixes in DXF exporter - fixes 0001590, 0001653 * Fixed arc directions * Turned max spline segment length preference option into a float * Fixed ellipses export |
Affected Issues 0001590, 0001653 |
| mod - src/Mod/Draft/Draft_rc.py | Diff File | ||
| mod - src/Mod/Draft/Resources/ui/userprefs-import1.ui | Diff File | ||
| 2014-07-30 15:59 | triplus | New Issue | |
| 2014-07-30 22:08 | yorik | Relationship added | duplicate of 0001590 |
| 2014-07-30 22:08 | yorik | Assigned To | => yorik |
| 2014-07-30 22:08 | yorik | Status | new => assigned |
| 2014-08-28 17:02 | yorik | Changeset attached | => FreeCAD Master master 16ede0e5 |
| 2014-08-28 17:02 | yorik | Status | assigned => closed |
| 2014-08-28 17:02 | yorik | Resolution | open => fixed |
