0001734SketcherBugpublic2017-12-12 21:47
Reportermiscjunk Assigned Toabdullah
Status closedResolutionfixed
OSWindowsOS Version7
Product Version0.14
Target Version0.17Fixed in Version0.17
Summary0001734: Constraints evaluated incorrectly while dragging a point with the mouse
DescriptionDragging a point constrained to an arc in an under-constrained sketch sometimes results in the point moving around erratically - being forced to a position not being pointed to by the mouse. I have confirmed this is not due to dragging the point to an invalid location - since when you release the point and re-drag it to the same location, it works.
Steps To Reproduce1. Open the attached file.
2. Drag one of the points on the 45deg lines which are constrained to the inner circle (see image: http://i.imgur.com/af2ZKn2.png) - around the circumference of the inner circle.
3. As the point is dragged around the inner circle, the drawing changes based on the constraints. However, at certain places around the circumference the point being dragged erratically moves to another point on the circumference not being pointed to by the pointer. I've confirmed that it is not a matter of those locations to which the point is being dragged to as being invalid constraints. If you release the mouse, and re-drag the point to the same location, it works.
Additional InformationOS: Windows 7
Word size: 32-bit
Version: 0.14.3700 (Git)
Branch: releases/FreeCAD-0-14
Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1
Python version: 2.6.2
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.5.1
Tagsconstraints, dragging
Relationships
related to 0000754 assignedabdullah GCS Sketcher doesn't report that a fully constrained sketch may have multiple (finite) solutions
miscjunk
2014-09-05 12:30
reporter
drag_problem.FCStd (3,473 bytes)
bejant
2014-09-05 14:47
reporter   ~0005076
This ticket may be a duplicate of ticket 0000754
Relevant forum thread for this ticket:
http://forum.freecad.org/viewtopic.php?f=3&t=7589
2016-10-21 15:08
administrator
2016-10-21 15:20
administrator   ~0007412
Still happens with 0.17. When releasing the dragged point after moving a quarter of the circle and then dragging again the jumping doesn't occur. However, it again happens after moving the next quarter of the circle. Looks like there is flip of the sign of the solution.
2017-10-19 11:43
administrator   ~0010330
Is this ticket in fact a dupe of 0000754 ?
2017-12-09 17:19
administrator   ~0010559
Requesting feedback on a way forward with this bug: https://forum.freecad.org/viewtopic.php?p=203580#p203580
abdullah
2017-12-11 15:38
manager   ~0010566
https://github.com/FreeCAD/FreeCAD/pull/1157
2017-12-12 21:47
administrator   ~0010594
https://github.com/FreeCAD/FreeCAD/commit/eff8529ec6ca4a530740b2a03322679804ff070d
2014-09-05 12:30 miscjunk New Issue
2014-09-05 12:30 miscjunk File Added: drag_problem.FCStd
2014-09-05 14:47 bejant Note Added: 0005076
2014-09-05 14:48 bejant Note Edited: 0005076
2016-10-21 15:08 wmayer File Added: 0001734.png
2016-10-21 15:20 wmayer Note Added: 0007412
2016-10-21 15:20 wmayer Status new => confirmed
2017-09-27 12:31 Kunda1 Tag Attached: constraints
2017-09-27 12:32 Kunda1 Relationship added related to 0000754
2017-10-19 11:43 Kunda1 Note Added: 0010330
2017-12-09 17:19 Kunda1 Note Added: 0010559
2017-12-10 21:01 Kunda1 Tag Attached: dragging
2017-12-10 21:01 Kunda1 Target Version => 0.17
2017-12-10 21:05 Kunda1 Assigned To => abdullah
2017-12-10 21:05 Kunda1 Status confirmed => assigned
2017-12-11 15:38 abdullah Note Added: 0010566
2017-12-12 21:47 wmayer Status assigned => closed
2017-12-12 21:47 wmayer Resolution open => fixed
2017-12-12 21:47 wmayer Fixed in Version => 0.17
2017-12-12 21:47 wmayer Note Added: 0010594
