| 0001739 | Part | General | public | 2014-09-10 13:16 | 2021-02-06 06:46 |
| Reporter | ickby | Assigned To | ickby | ||
| Summary | 0001739: Sweep tolerances are too high | ||||
| Description | Cuts with sweeps often fail, see the example given in thread http://forum.freecadweb.org/viewtopic.php?f=3&t=7612 By investigation it can be shown that this is a tolerance issue which can be fixed from freecad side. Let me explain: If you use part measure tool to measure the distance between the sweep vertex and the box face gives 7.26nm, which is 7.6290e-06mm (freecad shape tolerances are given in mm). The Vertex itself has a Tolerance value of 1.53e-05 assigned. this means the face is in tolerance of the vertex. However, the edge has a tolerance of 1e-7 assigned (Prcision::Confusion, the standart) and is therefore NOT in region of the face at the vertex location, but it only has a intersection with the face at a different lcoation then the vertex. It is quite clear that this situation must fail. To resolved this I used the OpenScad increase tolerance tool to increase the sweep tolerances to 1e-7, as it should have been from begining. With this sweep all cuts work nicely. The sweep should therefore be fixed to use Precision::Confusion per default. Either search for a correct constructor of the c++ class or change the tolerances after creation. One drawback however stays, but this is somethign for another issue: The distance between the vertex and the cut box is still too high for normal tolerances. OCC creates only one new vertex, not a vertex and a intersection with the edge, which is very sensible. This works by an increased tolerance of the new vertex, which gives the expected result for the user but which is bad for follow-up operations. We have to find out why the distance is bigger then the tolerance and fix this. | ||||
| Steps To Reproduce | load the file feder and recompute the document. To see the working fix load feder_fixed and see the result. | ||||
| Tags | sweep, tolerances | ||||
ickby, glad you are looking into this. your statement: "To resolved this I used the OpenScad increase tolerance tool to increase the sweep tolerances to 1e-7, as it should have been from begining. With this sweep all cuts work nicely." confuses me. The OpenScad tolerance feature increases the vertex tolerances to 0.1. From DRAWEXE: Draw[3]> restore first.brep first Draw[4]> restore second.brep second Draw[5]> tolerance first Tolerance MAX=1.53540271460213e-05 AVG=8.8165869405836007e-06 MIN=9.9999999999999995e-08 FACE : MAX=9.9999999999999995e-08 AVG=9.9999999999999995e-08 MIN=9.9999999999999995e-08 EDGE : MAX=9.9999999999999995e-08 AVG=9.9999999999999995e-08 MIN=9.9999999999999995e-08 VERTEX : MAX=1.53540271460213e-05 AVG=1.53540271460213e-05 MIN=1.53540271460213e-05 Draw[6]> tolerance second Tolerance MAX=0.10000000000000001 AVG=0.057142900000000003 MIN=9.9999999999999995e-08 FACE : MAX=9.9999999999999995e-08 AVG=9.9999999999999995e-08 MIN=9.9999999999999995e-08 EDGE : MAX=9.9999999999999995e-08 AVG=9.9999999999999995e-08 MIN=9.9999999999999995e-08 VERTEX : MAX=0.10000000000000001 AVG=0.10000000000000001 MIN=0.10000000000000001 Where "first" is the sweep before the OpenScad tolerance feature and "second" is after. Did I miss something? You are aware that the bopalgo geometry check is complaining about continuity of swept geometry? |
did you export the final cut or the sweep to brep? I checked the tolerances on the sweep object and the tolerance_sweep object. The openscad tool allows to set the wanted tolerance and I have set it to 1e-7. When checking it with toelrance_sweep.Shape.Vertexes[0].Toelrance etc. it shows that the tolerance was increased to this value. The 0.1 tolerance can be observed after the cut and is an issue we have to look further into. that is what I entitled a "further drawback" in my original post. But this is IMHO something seperate and need an own issue. I was not aware of the continuity issue with this particular sweep, thanks for pointing it out, but have seen this before. I think we should look into this too to understand why this occurs (and why this is a problem), maybe this function helps with fixing this: http://dev.opencascade.org/doc/refman/html/class_b_rep_offset_a_p_i___make_pipe_shell.html#a19bd34665e3f612621cee16271f2d4e9 . But it is also possible that we fix the c0 issue with tighter tolerancey, as it could be possible that the c0 geometry is only c0 because of a lack of precison... but this is wild guessing. To fix the tolerance issue I think we can use http://dev.opencascade.org/doc/refman/html/class_b_rep_offset_a_p_i___make_pipe_shell.html#a56df032bc1be96f5d41f823cf0114495 |
Whoops. Sweep feature was "first" and Tolerance_Sweep(openscad) was "second". The file you posted had the openscad feature set to 0.1. That was messing me up. So I adjusted the openscad tolerance feature to 1e-07 and the final cut was messed up again. I then exported the 3 breps out to draw again and here is what I got: Draw[6]> tolerance first Tolerance MAX=1.53540271460213e-05 AVG=8.8165869405836007e-06 MIN=9.9999999999999995e-08 FACE : MAX=9.9999999999999995e-08 AVG=9.9999999999999995e-08 MIN=9.9999999999999995e-08 EDGE : MAX=9.9999999999999995e-08 AVG=9.9999999999999995e-08 MIN=9.9999999999999995e-08 VERTEX : MAX=1.53540271460213e-05 AVG=1.53540271460213e-05 MIN=1.53540271460213e-05 Draw[7]> tolerance second Tolerance MAX=1.53540271460213e-05 AVG=8.8165869405836007e-06 MIN=9.9999999999999995e-08 FACE : MAX=9.9999999999999995e-08 AVG=9.9999999999999995e-08 MIN=9.9999999999999995e-08 EDGE : MAX=9.9999999999999995e-08 AVG=9.9999999999999995e-08 MIN=9.9999999999999995e-08 VERTEX : MAX=1.53540271460213e-05 AVG=1.53540271460213e-05 MIN=1.53540271460213e-05 Draw[8]> tolerance finalCut Tolerance MAX=1.53540271460213e-05 AVG=6.1633279253641203e-06 MIN=9.9999999999999995e-08 FACE : MAX=9.9999999999999995e-08 AVG=9.9999999999999995e-08 MIN=9.9999999999999995e-08 EDGE : MAX=5.0000000000000004e-06 AVG=1.3249999999999998e-06 MIN=9.9999999999999995e-08 VERTEX : MAX=1.53540271460213e-05 AVG=9.5298868763843228e-06 MIN=5.0000000000000004e-06 "first" = the original sweep. "second" = openscad tolerance feature. set 1e-07 "finalCut" = the last boolean cut feature. I did this twice to make sure I didn't mess something up. It appears the tolerance feature didn't tighten any tolerances. At least here. "BRepOffsetAPI_MakePipeShell::SetForceApproxC1" would be simple to try. I don't know if the continuity is the cause of any problems, but it can't help. we could try "BRepOffsetAPI_MakePipeShell::SetTolerance" to see what happens. |
BRepOffsetAPI_MakePipeShell::SetForceApproxC1 doesn't appear to be the answer. See uploaded file. |
tried "makeSweep.SetTolerance(Precision::Confusion(), Precision::Confusion(), Precision::Angular());" tolerances from drawexe: Draw[5]> tolerance tol Tolerance MAX=1.62647393406168e-06 AVG=9.7227081946381715e-07 MIN=9.9999999999999995e-08 FACE : MAX=9.9999999999999995e-08 AVG=9.9999999999999995e-08 MIN=9.9999999999999995e-08 EDGE : MAX=9.9999999999999995e-08 AVG=9.9999999999999995e-08 MIN=9.9999999999999995e-08 VERTEX : MAX=1.62647393406168e-06 AVG=1.62647393406168e-06 MIN=1.62647393406168e-06 slight change. tried subtraction of 2 cubes and got a different output, but still invalid. |
Tried both the tolerance and the forceC1 and made some progress. Got a good looking solid that passed the bopalgo check. still failed on the boolean cuts. I am thinking that this is a boolean problem and not a tolerance problem. construction snippet: BRepOffsetAPI_MakePipeShell makeSweep(helix); makeSweep.SetMode(true); //frenet makeSweep.SetTransitionMode(BRepBuilderAPI_RightCorner); makeSweep.SetForceApproxC1(true); makeSweep.SetTolerance(Precision::Confusion(), Precision::Confusion(), Precision::Angular()); makeSweep.Add(circle); makeSweep.Build(); makeSweep.MakeSolid(); TopoDS_Shape output = makeSweep.Shape(); |
I can confirm the issue: http://forum.freecadweb.org/viewtopic.php?f=3&t=12584&p=101155#p101155 |
Here is another example of this bug of leaving out a sliver of tolerance so a PartDesign additive or subtractive pipe will be incomplete. https://forum.freecadweb.org/viewtopic.php?f=3&t=24266 The work around is to use 2 overlapping sweeps to do a cut operation. |
Since in two days will be the three year anniversary of this bug, is it time to institute a workaround in the GUI? It seems that one profile to sweep in one location is enough to do a cut successfully using PartDesign subtractive pipe. The method is to sweep clockwise a segments, and also sweep CCW b segments, where n is the total number of segments to make a closed loop, and a + b = n + 1. A workaround could be to do one sweep with a new GUI button that skips selecting individual segments, and the button is called sweep all segments. It would sweep CW n segments, then add a sweep CCW of 1 segment. |
@kunda1 Hi! This ticket is not "sketcher" related. Is it possible to move it, maybe to project "Part"? |
@abdullah done ;) |
This ticket has been migrated to GitHub as issue 5594. |
| 2014-09-10 13:16 | ickby | New Issue | |
| 2014-09-10 13:16 | ickby | Status | new => assigned |
| 2014-09-10 13:16 | ickby | Assigned To | => ickby |
| 2014-09-10 13:16 | ickby | File Added: feder_fixed.fcstd | |
| 2014-09-10 13:18 | ickby | Description Updated | |
| 2014-09-10 13:22 | ickby | Description Updated | |
| 2014-09-10 13:32 | ickby | File Added: feder.fcstd | |
| 2014-09-10 15:55 | shoogen | Tag Attached: tolerances | |
| 2014-09-11 01:00 | tanderson69 | Note Added: 0005085 | |
| 2014-09-11 05:50 | ickby | Note Added: 0005088 | |
| 2014-09-11 05:53 | ickby | Note Edited: 0005088 | |
| 2014-09-11 13:38 | tanderson69 | Note Added: 0005089 | |
| 2014-09-11 15:00 | tanderson69 | File Added: forceC1.brep | |
| 2014-09-11 15:01 | tanderson69 | Note Added: 0005090 | |
| 2014-09-11 15:18 | tanderson69 | Note Added: 0005091 | |
| 2014-09-11 15:35 | tanderson69 | Note Added: 0005092 | |
| 2015-01-25 15:42 | yorik | Target Version | 0.15 => |
| 2015-09-26 12:38 | triplus | Note Added: 0006461 | |
| 2017-02-17 13:54 | Kunda1 | Tag Attached: sweep | |
| 2017-09-08 15:22 | industromatic | Note Added: 0010092 | |
| 2017-09-08 15:31 | industromatic | Note Added: 0010093 | |
| 2017-12-07 05:08 | abdullah | Note Added: 0010529 | |
| 2017-12-07 05:09 | Kunda1 | Project | Sketcher => Part |
| 2017-12-07 05:09 | Kunda1 | Category | Bug => General |
| 2017-12-07 05:10 | Kunda1 | Note Added: 0010530 | |
| 2017-12-07 05:10 | Kunda1 | Note Edited: 0010530 | |
