| 0001743 | File formats | public | 2014-09-12 19:58 | 2015-01-26 14:20 | |
| Reporter | mihlit | Assigned To | shoogen | ||
| Platform | Linux | OS | Fedora | OS Version | 20 |
| Summary | 0001743: dxf import/export does not work | ||||
| Description | I've tried to import attached dxf file (rib.dxf). It looks like import goes well (no error message), but the result is far from the original (wing rib with lightening holes). It uses curves and they go very wrong. See attached image (rib.png) for how the result looks and how it should look. Importing it for example in librecad works correctly, also online dxf viewer (https://gallery.proficad.com/tools/autocad-viewer.aspx) shows correct result. I've also tried exporting something to check whether freecad understands its own exports. I've tried a cut from a circle - a rectangle with a half circle on the opposite sides - a triangle loft. The cut looks like +- boat from behind. But when it's imported, there are no curves, just an approximation from a few lines. Attached cut.fcstd and cut.png | ||||
| Steps To Reproduce | Part one - importing the rib. 1) File - Open - rib.dxf Result: way too curvy, see attached picture how it should look. Part two - export-import 1) File - Open cut.fcstd 2) select Model -> cut -> Loft_cs 3) File - export -> cut.dxf 4) File - open -> cut.dxf Result: no curves, just 8 lines shape, see attached picture | ||||
| Additional Information | FreeCAD 0.14.3702 | ||||
| parent of | 0001934 | closed | FreeCAD | OCCT algorithms can't handle zero derivatives |
You must play a bit with the DXF export options (look in preferences->Draft), you can probably get better results than that. But I'll have a look too when I have a little time |
can you tell where you got the rib.dxf? |
Originally, I draw it in librecad, then I sent it to a guy with cnc milling machine to check it if he can use that. He said that it was ok, but it was made from too much lines, instead of paths and it would be ineffective (and expensive). So he fixed it in some software he uses and send it back. Unfortunately, I don't know what software he used. |
FreeCAD: master fe994efa 2015-01-02 20:05:27 Details Diff |
Draft: Fixed import of DXF splines - fixes 0001743 |
Affected Issues 0001743 |
FreeCAD: master c05f7762 2015-01-20 17:59:04 Details Diff |
import dxf splines as Draft BezCurve if applicable fixes 1743 |
| 2014-09-12 19:58 | mihlit | New Issue | |
| 2014-09-12 19:58 | mihlit | File Added: rib.dxf | |
| 2014-09-12 19:58 | mihlit | File Added: rib.png | |
| 2014-09-12 20:00 | mihlit | File Added: cut.fcstd | |
| 2014-09-12 20:01 | mihlit | File Added: cut.png | |
| 2014-09-12 22:01 | yorik | Note Added: 0005094 | |
| 2014-09-12 22:01 | yorik | Assigned To | => yorik |
| 2014-09-12 22:01 | yorik | Status | new => assigned |
| 2014-09-21 22:46 | yorik | Severity | major => minor |
| 2015-01-02 19:29 | yorik | Changeset attached | => FreeCAD Master master fe994efa |
| 2015-01-02 19:29 | yorik | Status | assigned => closed |
| 2015-01-02 19:29 | yorik | Resolution | open => fixed |
| 2015-01-16 15:18 | shoogen | Assigned To | yorik => shoogen |
| 2015-01-16 15:18 | shoogen | Note Added: 0005660 | |
| 2015-01-16 15:18 | shoogen | Status | closed => feedback |
| 2015-01-16 15:18 | shoogen | Resolution | fixed => reopened |
| 2015-01-16 18:57 | mihlit | Note Added: 0005661 | |
| 2015-01-16 18:57 | mihlit | Status | feedback => assigned |
| 2015-01-17 09:59 | shoogen | File Added: dxf-spline-rib.png | |
| 2015-01-17 14:27 | shoogen | File Added: dxf-spline-rib2.png | |
| 2015-01-17 14:27 | shoogen | File Deleted: dxf-spline-rib.png | |
| 2015-01-20 17:18 | shoogen | File Added: dxf-spline-rib3.png | |
| 2015-01-20 17:19 | shoogen | File Deleted: dxf-spline-rib2.png | |
| 2015-01-20 20:24 | shoogen | Changeset attached | => FreeCAD Master master c05f7762 |
| 2015-01-20 20:24 | shoogen | Status | assigned => closed |
| 2015-01-20 20:24 | shoogen | Resolution | reopened => fixed |
| 2015-01-26 14:20 | shoogen | Relationship added | parent of 0001934 |
