| 0001934 | FreeCAD | Bug | public | 2015-01-26 14:16 | 2018-10-28 09:43 |
| Reporter | shoogen | Assigned To | |||
| Priority | none | Severity | minor | Reproducibility | have not tried |
| Summary | 0001934: OCCT algorithms can't handle zero derivatives | ||||
| Description | many OCCT algorithms fail if a derivative becomes zero. Those appear in Bezier curves when their first (or last) pole is duplicated. This seriously affects imported paths form SVG files and some SPLINES from DXF files. | ||||
| Additional Information | http://dev.opencascade.org/index.php?q=node/1053 | ||||
| Tags | bezier curve, OCC 7.3, OCC Bug, upstream | ||||
Related upstream tickets mentioned in http://dev.opencascade.org/index.php?q=node/1053: http://tracker.dev.opencascade.org/view.php?id=25104 (Edit: assigned to be potentially fixed in OCC 7.2.1) |
@ickby do you mind asking the OCCT devs to add http://tracker.dev.opencascade.org/view.php?id=25730 to their roadmap ? |
Good news, Upstream 25730 is slated to be fixed in 7.2.0 according to their roadmap. |
Upstream 25730 is fixed in 7.2.0 ! Upstream 25104 is slated to be fixed in |
Upstream 25104 is slated to be fixed in 7.3 Please confirm fix @wmayer |
@tanderson69 would you mind testing this using OCC7.3 ? |
The initial post is about a bug in OCCT and does not refer to an explicit use case where this error would occur. |
| 2015-01-26 14:16 | shoogen | New Issue | |
| 2015-01-26 14:16 | shoogen | Tag Attached: OCC Bug | |
| 2015-01-26 14:20 | shoogen | Relationship added | child of 0001743 |
| 2015-01-26 14:21 | shoogen | Summary | OCCT algorithms can't handle a zero derivatives => OCCT algorithms can't handle zero derivatives |
| 2017-01-10 16:01 | Kunda1 | Tag Attached: upstream | |
| 2017-01-15 04:39 | Kunda1 | Note Added: 0007779 | |
| 2017-01-15 04:41 | Kunda1 | Tag Attached: OCC 7.2 | |
| 2017-01-15 04:41 | Kunda1 | Note Edited: 0007779 | |
| 2017-01-17 17:21 | Kunda1 | Tag Attached: bezier curve | |
| 2017-01-27 02:24 | Kunda1 | Tag Attached: bump | |
| 2017-08-22 11:49 | Kunda1 | Tag Detached: OCC 7.2 | |
| 2017-08-22 11:49 | Kunda1 | Tag Attached: OCC 7.2.1 | |
| 2017-08-22 11:49 | Kunda1 | Note Edited: 0007779 | |
| 2017-08-22 11:50 | Kunda1 | Note Added: 0009991 | |
| 2017-08-22 11:51 | Kunda1 | Tag Attached: OCC Unscheduled | |
| 2017-08-22 11:56 | Kunda1 | Tag Renamed | OCC Unscheduled => OCC NotOnRoadmap |
| 2017-08-27 12:34 | Kunda1 | Note Added: 0010012 | |
| 2017-08-27 12:34 | Kunda1 | Tag Attached: OCC 7.2 | |
| 2017-08-27 12:35 | Kunda1 | Note Edited: 0007779 | |
| 2017-08-27 12:36 | Kunda1 | Note Edited: 0007779 | |
| 2017-08-27 12:36 | Kunda1 | Tag Detached: OCC NotOnRoadmap | |
| 2017-09-02 11:02 | Kunda1 | Note Added: 0010058 | |
| 2017-09-02 11:04 | Kunda1 | Note Edited: 0007779 | |
| 2017-09-02 11:05 | Kunda1 | Tag Detached: bump | |
| 2018-01-18 13:36 | Kunda1 | Tag Attached: #tobeclosed | |
| 2018-01-18 13:37 | Kunda1 | Status | new => acknowledged |
| 2018-06-12 20:12 | Kunda1 | Tag Detached: OCC 7.2.1 | |
| 2018-06-12 20:12 | Kunda1 | Tag Detached: OCC 7.2 | |
| 2018-06-12 20:13 | Kunda1 | Tag Attached: OCC 7.3 | |
| 2018-06-12 20:13 | Kunda1 | Note Added: 0011415 | |
| 2018-06-12 20:14 | Kunda1 | Note Edited: 0010058 | |
| 2018-06-12 20:15 | Kunda1 | Target Version | => 0.18 |
| 2018-07-05 01:26 | Kunda1 | Note Added: 0011495 | |
| 2018-09-24 18:05 | wmayer | Status | acknowledged => closed |
| 2018-09-24 18:05 | wmayer | Resolution | open => no change required |
| 2018-09-24 18:05 | wmayer | Fixed in Version | => 0.18 |
| 2018-09-24 18:05 | wmayer | Note Added: 0011828 | |
| 2018-10-28 09:43 | Kunda1 | Tag Detached: #tobeclosed |
