| 0001751 | Arch | Bug | public | 2014-09-16 18:47 | 2019-01-04 21:34 |
| Reporter | microelly2 | Assigned To | yorik | ||
| Priority | low | Severity | minor | Reproducibility | have not tried |
| OS | ubuntu 14 lts | ||||
| Target Version | 0.18 | ||||
| Summary | 0001751: 3d views from mesh - some generated shapes have errors | ||||
| Description | mittelteil is the stl-output-reimport of a part using arch::3d view from mesh shape002 is okay but shape and shape001 have errors. I cannot part::intersect the part::extrudes generated from these shapes. | ||||
| Additional Information | when you draft downgrade the shapes you get one closed wire for shape002 but multiple pieces for shape and shape 2 | ||||
| Tags | #post-to-forum | ||||
Yeah... this is still very buggy... Don't expect it to work smoothly yet |
Possible alternative, faster algorithm: http://scialert.net/fulltext/?doi=itj.2007.914.918 |
@microelly2 can you re-up the attachment ? (we lost it in the restore) |
@microelly2 ping |
@microelly2 ping |
I can't get @microelly2 to respond |
In any case this is likely to never be fixed as we're kind of abandoning this way (generate these equipments from meshes) in favor of the Arch HiRes system. So I think it can be closed. Reopen if needed! |
| 2014-09-16 18:47 | microelly2 | New Issue | |
| 2014-09-16 18:47 | microelly2 | File Added: t.fcstd | |
| 2014-09-16 19:39 | yorik | Assigned To | => yorik |
| 2014-09-16 19:39 | yorik | Status | new => assigned |
| 2014-09-16 19:40 | yorik | Note Added: 0005109 | |
| 2015-01-19 17:33 | yorik | Priority | normal => low |
| 2015-08-05 02:06 | yorik | Note Added: 0006268 | |
| 2017-02-20 19:53 | Kunda1 | Summary | 3d views from mesh - some generated shapes have erros => 3d views from mesh - some generated shapes have errors |
| 2017-07-12 12:49 | Kunda1 | Note Added: 0009739 | |
| 2017-07-12 12:49 | Kunda1 | Status | assigned => feedback |
| 2017-08-23 12:00 | Kunda1 | Note Added: 0009998 | |
| 2017-08-23 12:01 | Kunda1 | Tag Attached: #post-to-forum | |
| 2017-10-16 19:44 | Kunda1 | Note Added: 0010306 | |
| 2018-01-12 15:09 | yorik | Target Version | => 0.18 |
| 2018-08-01 03:04 | Kunda1 | Note Added: 0011577 | |
| 2019-01-04 19:06 | Kunda1 | Note Added: 0012374 | |
| 2019-01-04 21:34 | yorik | Note Added: 0012375 | |
| 2019-01-04 21:34 | yorik | Status | feedback => closed |
| 2019-01-04 21:34 | yorik | Resolution | open => won't fix |
