| 0001766 | FreeCAD | Feature | public | 2014-09-26 13:52 | 2015-01-20 23:26 |
| Reporter | shoogen | Assigned To | yorik | ||
| Summary | 0001766: There is no GUI to set the default License and Company | ||||
| Description | There is no GUI to set the default License and Company And old files that don't bear any license information will be changed to CC-BY | ||||
Good point. It should be easy to add a couple of preference fields... |
I think we should remove the Company and Author Dialog for IGES and STEP export. They should use the value set for the document. |
Would it be better still run the dialogue but to fill the fields by default with the document values? It would allow you the advantage of 1) reminding you to enter a value if you have not already 2) remind you what value is going to be entered in case you forgot all about it 3) allow you to easy export to a different license or company name without effecting the original document? |
This is now fixed together with 0001883 |
| 2014-09-26 13:52 | shoogen | New Issue | |
| 2014-09-27 18:57 | yorik | Note Added: 0005160 | |
| 2014-12-12 21:33 | shoogen | Note Added: 0005372 | |
| 2014-12-30 10:58 | shoogen | Relationship added | related to 0001883 |
| 2015-01-07 14:52 | jmaustpc | Note Added: 0005555 | |
| 2015-01-20 23:26 | yorik | Note Added: 0005683 | |
| 2015-01-20 23:26 | yorik | Status | new => closed |
| 2015-01-20 23:26 | yorik | Assigned To | => yorik |
| 2015-01-20 23:26 | yorik | Resolution | open => fixed |
| 2015-01-20 23:26 | yorik | Fixed in Version | => 0.15 |
