| 0001786 | Draft | Feature | public | 2014-10-13 14:59 | 2021-02-06 06:45 |
| Reporter | more11 | Assigned To | |||
| Platform | Dell XPS | OS | Windows 7 | OS Version | 64 bit |
| Summary | 0001786: Change default draft precision to allow planar surfaces from dwire | ||||
| Description | See forum discussion: http://forum.freecadweb.org/viewtopic.php?f=3&t=7989 Increase default precision to 8 digits in order to avoid extrusion problems. Alternatively don't truncate position values when using snap. | ||||
OS: Windows 7 Word size: 64-bit Version: 0.14.3700 (Git) Branch: releases/FreeCAD-0-14 Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1 Python version: 2.7.6 Qt version: 4.8.5 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.6.0 |
increasing the draft precision will break code elsewhere (liuke dxf and svg import). IMHO changing snapping should be the preferable solution. |
There is also a problem with tessellation. I have another thread about that at the forum: http://forum.freecadweb.org/viewtopic.php?f=3&t=8042 Maybe change the default tessellation value to 0.05% as well? |
This ticket has been migrated to GitHub as issue 5598. |
| 2014-10-13 14:59 | more11 | New Issue | |
| 2014-10-13 16:34 | more11 | Note Added: 0005212 | |
| 2014-10-13 16:58 | shoogen | Note Added: 0005213 | |
| 2014-10-16 16:23 | more11 | Note Added: 0005223 | |
| 2017-01-22 21:17 | wmayer | Project | FreeCAD => Draft |
| 2017-03-02 16:49 | Kunda1 | Summary | Change default draft precision to allow planar survfaces from dwire => Change default draft precision to allow planar surfaces from dwire |
