| 0001813 | FreeCAD | Bug | public | 2014-11-02 17:37 | 2015-01-24 13:27 |
| Reporter | hobbes1069 | Assigned To | shoogen | ||
| Priority | normal | Severity | crash | Reproducibility | have not tried |
| Platform | Linux | OS | Fedora | OS Version | 20 |
| Summary | 0001813: freecad: qutr2d_(): FreeCAD killed by SIGSEGV | ||||
| Description | Description of problem: Exporting to .scad format Version-Release number of selected component: freecad-0.13-10.fc20 Additional info: reporter: libreport-2.2.2 backtrace_rating: 4 cmdline: /usr/bin/FreeCAD crash_function: qutr2d_ executable: /usr/lib64/freecad/bin/FreeCAD kernel: 3.15.5-200.fc20.x86_64 runlevel: N 5 type: CCpp uid: 1000 Truncated backtrace: Thread no. 1 (10 frames) #0 qutr2d_ at /lib64/libStdMeshers.so.5.1 #1 qualitetrte_ at /lib64/libStdMeshers.so.5.1 0000002 aptrte(long, double, long, long*, R2*, long, R2*, long&, R2*&, long&, long*&, long&) at /lib64/libStdMeshers.so.5.1 0000003 StdMeshers_MEFISTO_2D::Compute(SMESH_Mesh&, TopoDS_Shape const&) at /lib64/libStdMeshers.so.5.1 0000004 SMESH_subMesh::ComputeStateEngine(int) at /lib64/libSMESH.so.5.1 0000005 SMESH_Gen::Compute(SMESH_Mesh&, TopoDS_Shape const&, bool, MeshDimension, std::set<int, std::less<int>, std::allocator<int> >*) at /lib64/libSMESH.so.5.1 0000007 MeshPart::Mesher::createMesh() const at /usr/lib64/freecad/lib/MeshPart.so 0000008 meshFromShape(_object*, _object*) at /usr/lib64/freecad/lib/MeshPart.so 0000009 PyEval_EvalFrameEx at /lib64/libpython2.7.so.1.0 0000014 PyEval_EvalCodeEx at /lib64/libpython2.7.so.1.0 | ||||
| Additional Information | https://bugzilla.redhat.com/show_bug.cgi?id=1159646 | ||||
| Tags | SMESH | ||||
The full version info for FreeCAD is missing. |
That's v0.13.1830 which is obsolete. Current version is 0.14.3702 on GNU/Linux released July 14th 2014. I don't think this will be fixed in an obsolete FreeCAD version. |
Let me double check but you may be right. 0.14 has been released in Fedora for some time. I don't know how this guy is running 0.13. |
The MEFISTO code has since been converted from FORTRAN to C. Version 0.13 is outdated. Please file a new ticket if this problem can be reproduced in newer versions. |
| 2014-11-02 17:37 | hobbes1069 | New Issue | |
| 2014-11-02 17:47 | shoogen | Tag Attached: SMESH | |
| 2014-11-02 17:47 | shoogen | Severity | minor => crash |
| 2014-11-02 18:19 | shoogen | Note Added: 0005265 | |
| 2014-11-02 18:31 | normandc | Note Added: 0005266 | |
| 2014-11-02 18:35 | hobbes1069 | Note Added: 0005267 | |
| 2015-01-24 13:27 | shoogen | Note Added: 0005705 | |
| 2015-01-24 13:27 | shoogen | Status | new => closed |
| 2015-01-24 13:27 | shoogen | Assigned To | => shoogen |
| 2015-01-24 13:27 | shoogen | Resolution | open => won't fix |
