| 0001818 | FreeCAD | Bug | public | 2014-11-07 14:20 | 2021-02-06 06:50 |
| Reporter | microelly2 | Assigned To | |||
| Summary | 0001818: Bool Op representation error | ||||
| Description | A Pocket on a Box or the bool difference of two part::Box: two of the orthogonal views in the 3D windows have errors hidden inner edges are shown! The case pad - pocket works fine. | ||||
| Steps To Reproduce | see the example file go through all ortho views | ||||
| Tags | #pending | ||||
I think this error is being caused by a forked model. A properly constructed model does not show this problem. See the dependency graph of the attached file. What is being seen visually in the 3D view is not the same that is seen mathematically inside FreeCAD when projecting the 2D view from a forked model. |
No, its not the fork, I have packed two cases into one file if you delete the pocket so that there are only the two cubes and the cut the representation error ist still there. the same if you delete the outer path. the error occurs already in the case cut: box - box (on my computer: OS: Ubuntu 14.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4159 (Git) Branch: master Hash: fa3a2a0d3a7a0a619ab6323e236376bb43636e79 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.1 |
Switch your "View from: X +ve" to "View from: X -ve" and leave "Axis aligned right: Y +ve" |
@microelly2 does 0001818:0005290 help ? |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20312 |
What quick61 suggests is for the creation of 2D projected views in the Drawing workbench. The problem in this bug report relates to the 3D view. It still persists in current master when switching to a standard view. But doing a zoom "Fit All" corrects the issue and it no longer appears afterwards. OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.9822 (Git) Build type: None Branch: master Hash: 0df4af4ba5e6edce825af6ecf6d024c704292633 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
Issue still persists in:
ref: https://forum.freecadweb.org/viewtopic.php?f=10&t=20312#p160229 |
https://youtu.be/pCDEJtFC6rs <== screencast showing issue |
This ticket has been migrated to GitHub as issue 5602. |
| 2014-11-07 14:20 | microelly2 | New Issue | |
| 2014-11-07 14:20 | microelly2 | File Added: error_inner_faces.fcstd | |
| 2014-11-07 19:46 | quick61 | Note Added: 0005288 | |
| 2014-11-07 19:49 | quick61 | Note Edited: 0005288 | |
| 2014-11-07 23:08 | microelly2 | Note Added: 0005289 | |
| 2014-11-07 23:57 | quick61 | Note Added: 0005290 | |
| 2017-01-20 01:53 | Kunda1 | Note Added: 0007893 | |
| 2017-01-20 01:53 | Kunda1 | Status | new => feedback |
| 2017-01-28 13:49 | Kunda1 | Note Added: 0008057 | |
| 2017-01-29 17:11 | normandc | Note Added: 0008085 | |
| 2017-01-29 17:11 | normandc | Note Edited: 0008085 | |
| 2017-02-16 14:27 | Kunda1 | Status | feedback => confirmed |
| 2017-02-16 14:27 | Kunda1 | Note Added: 0008322 | |
| 2017-02-16 14:27 | Kunda1 | Note Edited: 0008322 | |
| 2017-02-16 14:29 | Kunda1 | Note Edited: 0008322 | |
| 2017-02-16 14:32 | Kunda1 | Tag Attached: #pending | |
| 2017-02-16 16:07 | Kunda1 | Note Added: 0008323 | |
| 2019-03-06 11:40 | Kunda1 | Target Version | => 0.19 |
