| 0001821 | FreeCAD | Bug | public | 2014-11-09 16:50 | 2015-01-24 15:37 |
| Reporter | lanciaux | Assigned To | yorik | ||
| Summary | 0001821: ASCII - ARCH SURVEY - Modification 5912342e failed on 32 bits SUSE 12.3 or 13.1 | ||||
| Description | I have all latest python & Pivy libs installed when required to compile FreeCad as I follow its modifications for several months now Since this modification of FreeCad Master, I've had the program to stop immediately at main launch on 32 bits Suse 12.3 or 13.1 with similar text 'ascii' codec can't decode byte 0xc2 in position xyz ordinal not in range(128)' . But it works on Opensuse 13.1 64 bits except for this point in Arch command Survey. Traceback (most recent call last): File "/usr/local/Mod/Arch/ArchCommands.py", line 650, in addSelection self.callback(True) File "/usr/local/Mod/Arch/ArchCommands.py", line 748, in survey t = t.replace("^2","²") <type 'exceptions.UnicodeDecodeError'>: 'ascii' codec can't decode byte 0xc2 in position 0: ordinal not in range(128) | ||||
That changeset is not related to the problem, but I already found the cause here... |
I don't like this fix. I refuse to call it 'solution' I think this will fall apart, sooner or later. At least with python3 IMHO: the anno.LabelText should be a unicode object. So I would suggest to use the replace function on a unicode object with two unicode parameters. t.replace(u"^2",u"\N{SUPERSCRIPT TWO}") |
Erm Erm ... i didn't want to hurt anyone when I met this trouble. Here is my point with no technical idea : 1. Arch Survey command is well fixed with timestamp '039cacbf' ; 2. Main FreeCAD is not anymore runnable in OpenSuse 12.3 or 13.1 32 bits due to apparently some Python related trouble with Unicode and they have well emerged with '5912342e' modification ; 3. Because having poor knowledge in Python and unable to give - as now - appropriate code to fix, I've installed OpenSuse 13.2 64 bits on VirtualBox system which was failing since '5912342e' ... and FreeCAD works directly. Thus this is really in Python problem reside and Shoogen could be right - for what i have read about Python3 unicode just now, acceptable problem of Python2 could emerge faster with Python3. |
shoogen for me this is fixed. Do you want to work any more on it? |
Let's considered fixed for now, okay? Reopen if needed... |
FreeCAD: master 5912342e 2014-10-19 17:27:02 Details Diff |
+ support of home path with non-ASCII chars |
Affected Issues 0001821 |
| mod - src/App/ApplicationPy.cpp | Diff File | ||
| mod - src/App/FreeCADInit.py | Diff File | ||
| mod - src/Gui/FreeCADGuiInit.py | Diff File | ||
| mod - src/Main/MainGui.cpp | Diff File | ||
FreeCAD: master 039cacbf 2014-11-09 20:27:37 Details Diff |
Arch: fixed encoding problem in Survey tool - fixes 0001821 |
| mod - src/Mod/Arch/ArchCommands.py | Diff File | ||
| 2014-11-09 16:50 | lanciaux | New Issue | |
| 2014-11-09 19:17 | yorik | Changeset attached | => FreeCAD Master master 5912342e |
| 2014-11-09 19:27 | yorik | Note Added: 0005298 | |
| 2014-11-09 19:27 | yorik | Assigned To | => yorik |
| 2014-11-09 19:27 | yorik | Status | new => assigned |
| 2014-11-09 19:41 | yorik | Changeset attached | => FreeCAD Master master 039cacbf |
| 2014-11-09 19:41 | yorik | Status | assigned => closed |
| 2014-11-09 19:41 | yorik | Resolution | open => fixed |
| 2014-11-10 13:16 | shoogen | Note Added: 0005299 | |
| 2014-11-10 13:16 | shoogen | Status | closed => feedback |
| 2014-11-10 13:16 | shoogen | Resolution | fixed => reopened |
| 2014-11-10 13:25 | shoogen | Note Edited: 0005299 | |
| 2014-11-10 17:18 | lanciaux | Note Added: 0005300 | |
| 2014-11-10 17:18 | lanciaux | Status | feedback => assigned |
| 2014-11-11 18:37 | yorik | Relationship added | parent of 0001825 |
| 2014-11-11 18:37 | yorik | Relationship deleted | parent of 0001825 |
| 2014-11-11 18:37 | yorik | Relationship added | has duplicate 0001825 |
| 2014-11-11 19:03 | yorik | Relationship added | has duplicate 0001824 |
| 2015-01-19 17:17 | yorik | Note Added: 0005676 | |
| 2015-01-19 17:18 | yorik | Status | assigned => feedback |
| 2015-01-24 15:37 | yorik | Note Added: 0005711 | |
| 2015-01-24 15:37 | yorik | Status | feedback => closed |
| 2015-01-24 15:37 | yorik | Resolution | reopened => fixed |
| 2015-01-24 15:37 | yorik | Fixed in Version | => 0.15 |
