| 0001825 | FreeCAD | Bug | public | 2014-11-11 17:01 | 2014-12-29 21:19 |
| Reporter | lanciaux | Assigned To | yorik | ||
| Summary | 0001825: DRAFT - COTATION command - No way to have dimension of a radius, a circle or curved vertex | ||||
| Description | By using DRAFT Cotation command with ALT pressed to accomodate radius/curved dimensions, it fails with this message (close to problem of survey for vertex) Indiquez le premier point : Traceback (most recent call last): File "/usr/local/Mod/Arch/ArchCommands.py", line 654, in clearSelection self.callback(True) File "/usr/local/Mod/Arch/ArchCommands.py", line 681, in survey FreeCAD.ActiveDocument.removeObject(label) <class 'Base.FreeCADError'>: No document object found with name 'surveyLabel' Traceback (most recent call last): File "/usr/local/Mod/Arch/ArchCommands.py", line 650, in addSelection self.callback(True) File "/usr/local/Mod/Arch/ArchCommands.py", line 754, in survey t = t.encode("utf8").getUserPreferred()[0] <type 'exceptions.AttributeError'>: 'Base.Quantity' object has no attribute 'encode' | ||||
This is -provisorily at least, there is controversy going on :) - already fixed by issue 0001821 |
I do not agree with you 1821 has fixed (checked it already) 2d and 3d survey but 1d is having exception because there is some property missing. Do a trial. yours Ludovic (Belgium) |
Ah sorry, my bad... Indeed there was still a defect. It should be fixed now. |
Hello, this has fixed lengths but there are something that is still breakable; as there is at least 2 "t ... without .decode("utf8")" (lines 756 & 762) Maybe others but not yet discovered ! Sorry Ludovic (Belgium) Traceback (most recent call last): File "/usr/local/Mod/Arch/ArchCommands.py", line 660, in addSelection self.callback(True) File "/usr/local/Mod/Arch/ArchCommands.py", line 767, in survey FreeCAD.Console.PrintMessage("Object: " + n + ", Element: " + el + ", Length: " + t + "\n") <type 'exceptions.UnicodeDecodeError'>: 'ascii' codec can't decode byte 0xc2 in position 1: ordinal not in range(128) |
FreeCAD: master c07d2ad9 2014-11-11 23:11:31 Details Diff |
Draft - small (provisory) encoding fix - fixes 0001825 |
Affected Issues 0001825 |
| mod - src/Mod/Arch/ArchCommands.py | Diff File | ||
FreeCAD: master 2f78c021 2014-12-29 21:54:33 Details Diff |
Arch: Fixed encodings in Survey - fixes 0001825 |
| 2014-11-11 17:01 | lanciaux | New Issue | |
| 2014-11-11 18:36 | yorik | Note Added: 0005304 | |
| 2014-11-11 18:37 | yorik | Relationship added | child of 0001821 |
| 2014-11-11 18:37 | yorik | Relationship deleted | child of 0001821 |
| 2014-11-11 18:37 | yorik | Relationship added | duplicate of 0001821 |
| 2014-11-11 18:38 | yorik | Status | new => closed |
| 2014-11-11 18:38 | yorik | Assigned To | => yorik |
| 2014-11-11 18:38 | yorik | Resolution | open => duplicate |
| 2014-11-11 20:30 | lanciaux | Note Added: 0005306 | |
| 2014-11-11 20:30 | lanciaux | Status | closed => feedback |
| 2014-11-11 20:30 | lanciaux | Resolution | duplicate => reopened |
| 2014-11-11 22:13 | yorik | Note Added: 0005307 | |
| 2014-11-12 00:01 | yorik | Changeset attached | => FreeCAD Master master c07d2ad9 |
| 2014-11-12 00:01 | yorik | Status | feedback => closed |
| 2014-11-12 21:33 | lanciaux | Note Added: 0005308 | |
| 2014-11-12 21:33 | lanciaux | Status | closed => feedback |
| 2014-11-12 21:34 | lanciaux | Note Edited: 0005308 | |
| 2014-12-29 21:19 | yorik | Changeset attached | => FreeCAD Master master 2f78c021 |
| 2014-12-29 21:19 | yorik | Status | feedback => closed |
