| 0001823 | Arch | Bug | public | 2014-11-10 20:52 | 2021-09-21 08:56 |
| Reporter | lanciaux | Assigned To | yorik | ||
| Summary | 0001823: Working plane not reset under Arch when making new project | ||||
| Description | Current working plane settings are not reset after you create a new Project/Sheet. | ||||
| Steps To Reproduce | 1. Make anything you want 2. Go to Arch 3. Setup a plane setting by selecting any face of your model 4. Close this Project/Sheet without saving it 5. Create a new Project/Sheet | ||||
| Tags | python | ||||
Hm these are two independent things... I'm not sure if it would be a good thing or not to reset the work plane when opening a new model. You might have set it a certain way in another file, that might be convenient to keep it. Besides, at the moment there is no mechanism to detect when a new document is opened from python, so this feature cannot be imlemented right now. But let's leave it open, an idea could arise. |
@yorik can you weigh in on this again? |
Still no idea on how to detect when a new document has been created/opened :( |
@wmayer care to weigh in? |
This is now possible with the DocumentObserver. But since it can be disruptive, it's best to implement after the 0.18 release. |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=23&t=53021 |
New proposal: implementing per-document working plane
This ticket has been migrated to GitHub as issue 5603. |
| 2014-11-10 20:52 | lanciaux | New Issue | |
| 2014-11-10 23:55 | yorik | Note Added: 0005303 | |
| 2017-05-01 23:35 | Kunda1 | Tag Attached: python | |
| 2017-06-03 15:47 | Kunda1 | Note Added: 0009277 | |
| 2017-06-05 15:46 | yorik | Note Added: 0009287 | |
| 2017-10-18 11:03 | Kunda1 | Note Added: 0010313 | |
| 2017-10-27 19:35 | yorik | Assigned To | => yorik |
| 2017-10-27 19:35 | yorik | Status | new => assigned |
| 2018-01-12 15:43 | yorik | Target Version | => 0.18 |
| 2018-12-05 12:58 | yorik | Note Added: 0012237 | |
| 2018-12-05 12:58 | yorik | Target Version | 0.18 => |
| 2018-12-05 12:58 | yorik | Target Version | => 0.19 |
| 2020-07-05 16:44 | abdullah | Project | FreeCAD => Arch |
| 2020-12-08 01:41 | Kunda1 | Note Added: 0015116 | |
| 2021-02-06 06:28 | abdullah | Target Version | => 0.20 |
| 2021-09-21 08:56 | yorik | Note Added: 0015951 |
