| 0001858 | FreeCAD | Bug | public | 2014-12-16 21:37 | 2022-01-24 19:16 |
| Reporter | NikB | Assigned To | shoogen | ||
| Platform | x86 | OS | Windows | OS Version | 8 |
| Summary | 0001858: Loft tool incorrect result with rotated ellipses (Upstream OCC bug) | ||||
| Description | Loft tool gives unexpected result when using identical ellipses rotated. One end edge as expected, but other has scolloping, concave or convex dependent on two or more ellipses. | ||||
| Tags | #ready-for-migration, Bountysource Potential, bump, OCC Bug, OCC NotOnRoadmap, upstream | ||||
reproduceable in DRAWEXE of OCCT 6.8.1-dev reported as http://tracker.dev.opencascade.org/view.php?id=25626 |
Still reproducible on OCCT 7.1 and upstream isn't on the roadmap. Requires bump. |
@adbdullah would you be interested in bumping the upstream ticket in the hopes that it may be added to the OCC roadmap ? |
Original attachment is missing, and the attached files in the OCCT bug tracker can't be downloaded. A loft between three ellipses rotated 90 degrees from each other appear fine in FC 0.18-dev with latest OCCT 7.3.0... |
What should be we do about this ticket then? |
Maybe the OCCT bug tracker requires to be registered to download. Since @abdullah has an account, we could ask him to upload the files here so we could check with FreeCAD compiled with latest OCCT. From what I understand of the posted DRAWEXE script (in the upstream bug, "Steps to reproduce"), it reads from brep files that are probably included in the zip archive. |
Files are attached. I will indicate that the FC project is monitoring this ticket and whether it will be assigned to a roadmap. |
@normandc @Kunda1 Bugnote #0081082 added by MSV (developer) 2018-11-14 10:12 Dear abdullah, OCC has no fonds to solve this bug in the nearest future without external investment or contribution. You are welcome to propose your fix if you can. |
Unfortunately it is a too big shoe for my feet. |
Thanks, abdullah. I imported the 3 brep files into FreeCAD and created a Part Loft. I'm attaching it for future reference. The issue indeed persists with OCC 7.3.0. Ellipses are rotated only a few degrees, I had tried 90 degrees between each ellipse and that worked. I also tried a sweep with a straight line from (0,0,0) to (0,0,20) as path; same issue. That's a bummer on OCC's reply... |
This ticket has been migrated to GitHub as issue 6318. |
| 2014-12-16 21:37 | NikB | New Issue | |
| 2014-12-16 21:37 | NikB | File Added: prop001.FCStd | |
| 2014-12-17 10:14 | shoogen | Note Added: 0005400 | |
| 2014-12-17 10:14 | shoogen | Assigned To | => shoogen |
| 2014-12-17 10:14 | shoogen | Status | new => acknowledged |
| 2014-12-17 10:32 | shoogen | Note Edited: 0005400 | |
| 2014-12-17 10:32 | shoogen | Severity | major => minor |
| 2014-12-17 10:33 | shoogen | Tag Attached: OCC Bug | |
| 2017-01-15 04:34 | Kunda1 | Tag Attached: upstream | |
| 2017-01-27 01:26 | Kunda1 | Tag Attached: bump | |
| 2017-08-22 11:47 | Kunda1 | Note Added: 0009990 | |
| 2017-08-22 11:52 | Kunda1 | Tag Attached: OCC Unscheduled | |
| 2017-08-22 11:56 | Kunda1 | Tag Renamed | OCC Unscheduled => OCC NotOnRoadmap |
| 2018-10-19 13:36 | Kunda1 | Note Added: 0012071 | |
| 2018-11-11 06:18 | normandc | Note Added: 0012173 | |
| 2018-11-12 00:47 | Kunda1 | Note Added: 0012179 | |
| 2018-11-12 02:55 | normandc | Note Added: 0012180 | |
| 2018-11-13 17:51 | abdullah | File Added: loft-el1.zip | |
| 2018-11-13 17:51 | abdullah | File Added: loft-el1.png | |
| 2018-11-13 17:51 | abdullah | Note Added: 0012191 | |
| 2018-11-14 19:06 | abdullah | Note Added: 0012196 | |
| 2018-11-14 19:08 | abdullah | Note Added: 0012197 | |
| 2018-11-15 01:53 | normandc | File Added: FC_issue_0001858.fcstd | |
| 2018-11-15 01:53 | normandc | Note Added: 0012198 | |
| 2018-11-22 11:10 | Kunda1 | Tag Attached: potentialbounty | |
| 2018-12-24 12:52 | Kunda1 | Tag Renamed | potentialbounty => Bountysource Potential |
| 2020-01-14 17:39 | Kunda1 | Summary | Loft tool incorrect result with rotated ellipses => Loft tool incorrect result with rotated ellipses (Upstream OCC bug) |
