| 0001898 | FreeCAD | Bug | public | 2015-01-06 05:44 | 2017-01-11 13:23 |
| Reporter | Bibi | Assigned To | |||
| Platform | Mac and Windows | OS | Mac and Windows | OS Version | 10.7 and 7 |
| Target Version | 0.15 | Fixed in Version | 0.16 | ||
| Summary | 0001898: Drawing workbench draws cylinder in orthographic projection wrong | ||||
| Description | See explanation here: http://forum.freecad.org/viewtopic.php?f=3&t=9222 Same results on Mac and Windows and both versions: 0.14 and 0.15. | ||||
| Steps To Reproduce | See here: http://forum.freecad.org/viewtopic.php?f=3&t=9222 | ||||
| related to | 0001899 | closed | kkremitzki | Drawing | discretize in DrawingExport::printGeneric |
| related to | 0001912 | closed | wmayer | FreeCAD | Drawing Workbench Not Displaying Views of Cylindrical Parts. |
We could tweak the settings for the BSpline approximation once or we could make them available as Parameters in the DrawingGui preferences. |
Allowing to use different values for the approximation is troublesome because you will always find an example where the approximation works but badly fails for another one. IMO, it might be better to have a function that checks how close the spline is to a circle and if it's close enough compute an exact circle and use this instead. Therefore the spline can be discretized into three points first so that the center of the circle can be computed. Then the spline can be discretized into e.g. 30 points and if all of them have a distance to the center within a certain tolerance we can consider the spline as a circle. |
Please see http://forum.freecad.org/viewtopic.php?f=3&t=9289 This fix may have caused a new problem. |
Caused a regression when a line is represented as a b-spline curve. Then the circle check failed because the curvature center cannot be computed. |
is responsible for the reversed arcs. |
changed the severity to blocker, as this created a regression which is trivial to workaround for the 0.15 release. git://github.com/5263/FreeCAD bugfix-drawingarcs |
According to @NormandC in http://forum.freecad.org/viewtopic.php?f=3&t=9222&p=152696#p152696The problem appears to be fixed in OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6706 (Git) Build type: Release Branch: releases/FreeCAD-0-16 Hash: f86a4e411ff7848dea98d7242f43b7774bee8fa0 Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 Forcing a recompute fixes the Drawing views. |
| 2015-01-06 05:44 | Bibi | New Issue | |
| 2015-01-06 12:16 | shoogen | Note Added: 0005533 | |
| 2015-01-06 15:27 | shoogen | Relationship added | related to 0001899 |
| 2015-01-10 16:53 | wmayer | Note Added: 0005609 | |
| 2015-01-11 01:09 | wmayer | Changeset attached | => FreeCAD Master master 0a31beba |
| 2015-01-11 01:09 | wmayer | Assigned To | => wmayer |
| 2015-01-11 01:09 | wmayer | Status | new => closed |
| 2015-01-11 01:09 | wmayer | Resolution | open => fixed |
| 2015-01-11 22:30 | normandc | Note Added: 0005621 | |
| 2015-01-11 22:30 | normandc | Status | closed => feedback |
| 2015-01-11 22:30 | normandc | Resolution | fixed => reopened |
| 2015-01-12 00:46 | wmayer | Note Added: 0005627 | |
| 2015-01-12 00:46 | wmayer | Status | feedback => closed |
| 2015-01-12 00:46 | wmayer | Resolution | reopened => fixed |
| 2015-01-12 00:46 | wmayer | Fixed in Version | => 0.15 |
| 2015-01-25 00:47 | shoogen | Relationship added | related to 0001912 |
| 2015-02-10 12:13 | shoogen | Note Added: 0005779 | |
| 2015-02-10 12:13 | shoogen | Status | closed => feedback |
| 2015-02-10 12:13 | shoogen | Resolution | fixed => reopened |
| 2015-02-10 12:13 | shoogen | Severity | major => block |
| 2015-02-10 12:14 | shoogen | Fixed in Version | 0.15 => |
| 2015-02-10 12:14 | shoogen | Target Version | => 0.15 |
| 2015-02-10 15:28 | shoogen | Note Edited: 0005779 | |
| 2015-02-10 15:30 | shoogen | Note Added: 0005782 | |
| 2015-02-10 15:30 | shoogen | Status | feedback => assigned |
| 2016-07-28 17:21 | wmayer | Assigned To | wmayer => |
| 2017-01-11 01:48 | Kunda1 | Note Added: 0007620 | |
| 2017-01-11 01:48 | Kunda1 | Note Edited: 0007620 | |
| 2017-01-11 13:23 | wmayer | Status | assigned => closed |
| 2017-01-11 13:23 | wmayer | Resolution | reopened => fixed |
| 2017-01-11 13:23 | wmayer | Fixed in Version | => 0.16 |
