| 0001924 | FreeCAD | Bug | public | 2015-01-17 07:25 | 2017-01-31 17:53 |
| Reporter | wvmarle | Assigned To | |||
| Platform | Intel | OS | Linux | OS Version | Mint 17 |
| Summary | 0001924: Cutting (binary operation) fail. | ||||
| Description | My version is 0.15 which I can not select here. When cutting a hole in the cup, viewed from one side it seems OK, viewed from another side it's not. It's apparently related to a rather exact set of parameters. Changing the cylinder size makes it work as expected (it's related to the actual radius), changing location of the cylinder also makes it work fine, changing the rotation of the main object to <360° also makes it work fine. | ||||
| Additional Information | http://forum.freecadweb.org/viewtopic.php?f=3&t=9342 OS: Linux Mint 17 Qiana Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4484 (Git) Branch: master Hash: f72c802f5daa378298ffbfc3f3a17ec2d35c1816 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.1 | ||||
| Tags | boolean | ||||
per @normandC in http://forum.freecadweb.org/viewtopic.php?f=3&t=9342&start=20#p153459 > The file posted in the bug report appears fine after executing Macro ForceRecompute (http://www.freecadweb.org/wiki/index.php?title=Macro%20ForceRecompute) > I would close it. Resolving ticket (not sure what version to assign the fix to). Deferring to the devs for that. |
| 2015-01-17 07:25 | wvmarle | New Issue | |
| 2015-01-17 07:25 | wvmarle | File Added: cut test.fcstd | |
| 2015-01-20 11:44 | shoogen | Tag Attached: boolean | |
| 2017-01-15 01:09 | Kunda1 | Note Added: 0007774 | |
| 2017-01-15 01:09 | Kunda1 | Status | new => resolved |
| 2017-01-15 01:09 | Kunda1 | Resolution | open => fixed |
| 2017-01-15 01:09 | Kunda1 | Assigned To | => Kunda1 |
| 2017-01-15 01:09 | Kunda1 | Assigned To | Kunda1 => |
| 2017-01-31 17:53 | wmayer | Status | resolved => closed |
