| 0001973 | Draft | Feature | public | 2015-02-18 19:01 | 2018-12-07 13:15 |
| Reporter | r-frank | Assigned To | wandererfan | ||
| Platform | 64 bit | OS | Windows | OS Version | 7 |
| Summary | 0001973: Improve GUI of Shapestring-command | ||||
| Description | ATM you have to press "Return" to advance from sub-menu to sub-menu in the Shapestring-Command-Menu. Adding Arrow-Icons or Buttons to advance or putting all input fields in one big menu would improve User friendliness. | ||||
| Additional Information | See here for discussion: http://forum.freecadweb.org/viewtopic.php?f=8&t=9768 Opened a FR thread in the UI/UX subforum: https://forum.freecadweb.org/viewtopic.php?f=34&t=22739 | ||||
| Tags | #lowhangingfruit, shapestring, UI | ||||
| related to | 0002562 | new | Add Skew/Shear Angle to ShapeString |
A wizard should be used for this: http://qt-project.org/doc/qt-4.8/qwizard.html |
I don't think adding wizards for tools is a good idea, this breaks the interface design. Imho it would be better to find a ui layout for the task dialog where all options are displayed at once so that the user can switch by selecting the correct input field. Then the return key can be used like tab to switch between the fields, this would then not break the current way of navigating. |
Should be fixed by commit bdbdf8c6b7. |
| 2015-02-18 19:01 | r-frank | New Issue | |
| 2015-02-19 09:53 | wmayer | Note Added: 0005813 | |
| 2015-02-19 13:08 | ickby | Note Added: 0005814 | |
| 2017-01-19 17:06 | Kunda1 | Tag Attached: shapestring | |
| 2017-05-31 01:02 | Kunda1 | Tag Attached: UI | |
| 2017-05-31 17:47 | Kunda1 | Additional Information Updated | |
| 2017-12-04 14:45 | Kunda1 | Tag Attached: #lowhangingfruit | |
| 2018-10-02 21:27 | Kunda1 | Relationship added | related to 0002562 |
| 2018-12-02 14:25 | wandererfan | Note Added: 0012230 | |
| 2018-12-02 14:26 | wandererfan | Assigned To | => wandererfan |
| 2018-12-02 14:26 | wandererfan | Status | new => resolved |
| 2018-12-02 14:26 | wandererfan | Resolution | open => fixed |
| 2018-12-02 14:26 | wandererfan | Fixed in Version | => 0.18 |
| 2018-12-02 14:26 | wandererfan | Target Version | => 0.18 |
| 2018-12-07 13:15 | wandererfan | Status | resolved => closed |
