| 0001976 | FreeCAD | Bug | public | 2015-02-22 14:31 | 2018-09-22 15:48 |
| Reporter | JPouX | Assigned To | |||
| Platform | Windows | OS | 7 | OS Version | SP1 |
| Summary | 0001976: Error when sweeping a ruled surface | ||||
| Description | When sweeping a ruled surface, an error occurs. The first time I encountered this error, it wrote something like "Error when writing {adresses}". Then I re-launched FreeCAD and the error occured again, but without anything written in the error box. | ||||
| Steps To Reproduce | -Defining a ruled surface (in my case: a pipe cross section) -Defining a path -When making the sweep, the ruled surface appears in the column Vertex/edge/wire/face. -Selecting the rule surface as the sweeping section -Selecting the path -Clicking "OK" -It should fail | ||||
| Tags | #pending, sweep | ||||
Can you please provide your OCCT version. |
The sweep is not the problem. The Sketch001 is fails the BOPCheck and there should be a better way to get a planar face, than a ruled surface. >>> App.ActiveDocument.Sketch001.Shape.Vertexes[0].Tolerance 23.3429852075864 >>> App.ActiveDocument.Sketch001.Shape.Vertexes[1].Tolerance 23.3429852075864 |
There seems to be a problem with the ruled surface damaging the vertex tolerances |
@shoogen is this an upstream issue? |
@JPouX I know this is ancient history but is there any possibility you can reupload your attachment to this ticket? |
@Kunda1 Sorry, I have lost the files since then. |
@NormandC can you recreate this issue from scratch? |
@chrisb perhaps you can ? |
I think I did, based on what I could understand. But as shoogen wrote back in 2015, it does not make sense to create a ruled surface from a sketch. 3 years later, the PartDesign workbench now has an additive sweep tool that can sweep a sketch made of two closed profiles inside one another (like a pipe section). In the attached file FC_Issue1976_Sweep_Ruled_Surface_Error_nc1.fcstd, trying to generate a sweep using Ruled_Surface as profile and Sketch as path produces a BRepFill_Sweep::BuildEdge error. I believe we should ignore this issue and close the report as it's not a proper work flow anyway. |
As suggested by normandc the PD workbench offers a proper workflow to do this the right way. |
| 2015-02-22 14:31 | JPouX | New Issue | |
| 2015-02-22 14:31 | JPouX | File Added: Essai_tube.FCStd | |
| 2015-02-23 10:36 | shoogen | Note Added: 0005819 | |
| 2015-02-23 10:39 | shoogen | Note Added: 0005820 | |
| 2015-02-23 10:39 | shoogen | Assigned To | => shoogen |
| 2015-02-23 10:39 | shoogen | Status | new => feedback |
| 2015-02-23 11:53 | shoogen | Note Edited: 0005820 | |
| 2015-02-23 11:55 | shoogen | Note Added: 0005822 | |
| 2015-02-23 14:30 | shoogen | Assigned To | shoogen => wmayer |
| 2015-02-23 14:30 | shoogen | Status | feedback => assigned |
| 2015-02-23 14:36 | shoogen | Assigned To | wmayer => |
| 2015-02-24 10:25 | shoogen | Status | assigned => new |
| 2017-01-13 22:34 | Kunda1 | Note Added: 0007737 | |
| 2017-02-17 13:55 | Kunda1 | Tag Attached: sweep | |
| 2017-02-17 13:56 | Kunda1 | Tag Attached: #pending | |
| 2017-02-18 11:32 | Kunda1 | Status | new => feedback |
| 2017-05-13 12:32 | Kunda1 | Note Added: 0008983 | |
| 2017-05-17 15:09 | JPouX | Note Added: 0009040 | |
| 2017-05-17 15:09 | JPouX | Status | feedback => new |
| 2017-05-17 15:39 | Kunda1 | Note Added: 0009041 | |
| 2018-08-26 15:17 | Kunda1 | Note Added: 0011664 | |
| 2018-09-02 20:04 | normandc | File Added: FC_Issue1976_Sweep_Ruled_Surface_Error_nc1.fcstd | |
| 2018-09-02 20:04 | normandc | Note Added: 0011686 | |
| 2018-09-22 15:48 | wmayer | Status | new => closed |
| 2018-09-22 15:48 | wmayer | Resolution | open => won't fix |
| 2018-09-22 15:48 | wmayer | Note Added: 0011815 |
