0001981FreeCADBugpublic2017-07-11 20:12
Reporterned Assigned To
Status closedResolutionfixed
PlatformMacOSMac OS XOS Version10.10 (Yosemite)
Product Version0.14
Summary0001981: Some workbenches only work if FreeCAD is installed in /Applications
DescriptionFreeCAD modules only work if installed in /Applications. The Mac has a user-specific directory for apps installed by that user, in my case /Users/john/Applications. The nice thing is that installing apps in the user's Applications folder does not require administrator privileges.
If I install FreeCAD in /Users/john/Applications, then activating some workbenches fails with a pop up that says something like "must be string, not None".
FreeCAD's modules ought to work from my Downloads folder.
Steps To Reproduce1. Download FreeCAD and unzip it but leave it in the Downloads directory.
2. Optionally move it to /Users/myname/Applications.
3. Activate workbench (for example) Arch. (Some workbenches do not show this message)
Notice the error message: 'NoneType' object has no attribute 'file'
Also:
1. Download and unzip CadQuery.
2. Drag the CadQuery folder into the /Users/john/Applications/FreeCAD.app/Contents/Mod folder.
3. Activate workbench CadQuery.
Notice the error message: "must be string, not None"
Note that running FreeCAD from the terminal does NOT reproduce this problem for the Arch workbench. However, for the CadQuery module, it does:
$ cd /Users/john/Applications/FreeCAD.app/Contents/bin
$ ./FreeCAD -l
FreeCAD 0.14, Libs: 0.14R3703 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2011
Arch workbench activated
Arch workbench deactivated
2015-02-26 08:38:02.285 FreeCAD[41907:8721345] modalSession has been exited prematurely - check for a reentrant call to endModalSession:
In the above log, you can see that no error message was generated when activating Arch.
The error message "must be string, not None" was generated when I activated CadQuery.
Additional InformationIn general, Mac applications ought to be runnable directly from the Downloads (or any other folder) in which the user has permissions. FreeCad is runnable but some add on modules do not seem to work.
OS: Mac OS X
Word size: 64-bit
Version: 0.14.3703 (Git)
Branch: releases/FreeCAD-0-14
Hash: c6edd47334a3e6f209e493773093db2b9b4f0e40
Python version: 2.7.5
Qt version: 4.8.6
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
TagsmacOS
Relationships
related to 0002006 closedian.rees Make application bundle when building for MacOS
2017-01-19 19:52
administrator   ~0007887
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20062
2017-01-19 19:55
administrator   ~0007888
@ned please retest current stable 0.16
Thank you.
blacey
2017-01-19 20:02
developer   ~0007889
This is OBE. We build an Application bundle for macOS that includes all dependencies and is relocatable (i.e. can be run from anywhere it is placed). This can safely be closed.
2015-02-26 16:53 ned New Issue
2017-01-10 13:56 Kunda1 Tag Attached: MacOSX
2017-01-19 19:52 Kunda1 Note Added: 0007887
2017-01-19 19:55 Kunda1 Note Added: 0007888
2017-01-19 19:55 Kunda1 Status new => feedback
2017-01-19 19:55 Kunda1 Tag Attached: #pending
2017-01-19 19:55 Kunda1 Tag Attached: #tobeclosed
2017-01-19 20:02 blacey Note Added: 0007889
2017-01-19 20:03 Kunda1 Tag Detached: #pending
2017-01-19 20:03 Kunda1 Status feedback => closed
2017-01-19 20:03 Kunda1 Resolution open => fixed
2017-01-19 20:04 Kunda1 Relationship added related to 0002006
2017-07-11 20:12 Kunda1 Tag Detached: #tobeclosed
2020-11-13 14:08 Kunda1 Tag Renamed MacOSX => macOS
