| 0002008 | FreeCAD | Bug | public | 2015-03-18 20:09 | 2017-07-11 20:12 |
| Reporter | Jin | Assigned To | |||
| Platform | x86_64 linux | OS | Fedora | OS Version | 21 |
| Summary | 0002008: not possible to compile because Coin3d headers are not found | ||||
| Description | Current master head does not compile on Fedora 21, because the cmake scripts fail to find Coin3d includes. I.e.: free-cad-code/src/Gui/Utilities.cpp:27:32: fatal error: Inventor/SbMatrix.h: No such file or directory # include <Inventor/SbMatrix.h> The solution is to use pkg-config on Linux systems, this will resolve problems like these. I'd fix it myself it was autotools, but after an hour of battling cmake I gave up, so I hope someone else can do it. I can confirm, that when pasting the failed compile line (make VERBOSE=1) and manually adding the output from pkg-config Coin3 --cflags does allow to compile the sources that otherwise fail. Please refer to http://www.cmake.org/cmake/help/v3.0/module/FindPkgConfig.html | ||||
Forum thread: http://forum.freecadweb.org/viewtopic.php?f=4&t=19771 |
According to @wmayer (in http://forum.freecadweb.org/viewtopic.php?f=4&t=19771&p=152659#p152659) a commit was made (http://github.com/FreeCAD/FreeCAD/commit/6ee243c2fa) Therefore this ticket looks like it can be closed. Tagging #tobeclosed |
| 2015-03-18 20:09 | Jin | New Issue | |
| 2017-01-10 15:17 | Kunda1 | Note Added: 0007602 | |
| 2017-01-10 16:44 | Kunda1 | Note Added: 0007610 | |
| 2017-01-10 16:45 | Kunda1 | Tag Attached: #tobeclosed | |
| 2017-01-10 17:01 | wmayer | Status | new => closed |
| 2017-01-10 17:01 | wmayer | Resolution | open => fixed |
| 2017-01-10 17:01 | wmayer | Fixed in Version | => 0.17 |
| 2017-07-11 20:12 | Kunda1 | Tag Detached: #tobeclosed |
