| 0002024 | FreeCAD | Bug | public | 2015-03-23 16:38 | 2022-01-24 19:16 |
| Reporter | bhs67 | Assigned To | shoogen | ||
| OS | Windows 7 | OS Version | SP1 | ||
| Summary | 0002024: Boolean -> Difference leaves a extra hole (upstream OCC bug) | ||||
| Description | One attachment is a pdf indicating the problem. The other two attachments are before and after the Procedure. | ||||
| Steps To Reproduce | Procedure ... Part -> Boolean -> Boolean -> Difference -> (first shape) cube -> (second shape) total hollow fillet -> Apply. | ||||
| Tags | #ready-for-migration, bump, OCC Bug, OCC NotOnRoadmap, upstream | ||||
You did not mention whether you created this file with automated refines enabled. The total hollow fillet is invalid in both files. You did not specify your full FreeCAD version information. |
I am using FreeCad 0.14 rev 3700. Where do I find automated recomputes? |
sorry, i meant automated refines. The are enabled by a setting called "automatically refine shape after boolean operation" |
Hmmm. I checked the Preferences ... do not have "automatically refine model after boolean operation" checked. Should it be checked or not checked? Thanks! |
http://tracker.dev.opencascade.org/view.php?id=25979 |
@shoogen should we bump the upstream bug ? |
@ickby do you mind asking the upstream devs to assign this to their roadmap? |
Kunda: the bug has been verified against current OCCT recently and a test case has been added: 2017-08-07 18:16 I think this should be enough to gurantee the treatment, what do you think? |
@ickby it's your call. I personally would ask if they could at least assign it their 'unscheduled' list. |
This ticket has been migrated to GitHub as issue 5619. |
| 2015-03-23 16:38 | bhs67 | New Issue | |
| 2015-03-23 16:38 | bhs67 | File Added: bug after.FCStd | |
| 2015-03-23 16:39 | bhs67 | File Added: bug after.pdf | |
| 2015-03-23 16:39 | bhs67 | File Added: bug before.FCStd | |
| 2015-03-23 17:01 | shoogen | Note Added: 0005932 | |
| 2015-03-23 17:02 | shoogen | File Added: bug_repaired-no_autorefine.fcstd | |
| 2015-03-23 17:08 | shoogen | Note Edited: 0005932 | |
| 2015-03-23 17:14 | bhs67 | Note Added: 0005933 | |
| 2015-03-23 22:30 | shoogen | Note Edited: 0005932 | |
| 2015-03-23 22:30 | shoogen | Note Added: 0005936 | |
| 2015-03-24 14:58 | bhs67 | Note Added: 0005940 | |
| 2015-03-24 17:20 | shoogen | Note Edited: 0005932 | |
| 2015-03-24 17:21 | shoogen | Tag Attached: OCC Bug | |
| 2015-03-24 17:21 | shoogen | Assigned To | => shoogen |
| 2015-03-24 17:21 | shoogen | Status | new => acknowledged |
| 2015-03-24 17:37 | shoogen | Note Added: 0005941 | |
| 2017-01-15 04:36 | Kunda1 | Tag Attached: upstream | |
| 2017-01-15 15:22 | Kunda1 | Note Added: 0007797 | |
| 2017-01-27 02:22 | Kunda1 | Tag Attached: bump | |
| 2017-08-22 11:56 | Kunda1 | Tag Attached: OCC NotOnRoadmap | |
| 2017-08-27 12:38 | Kunda1 | Note Added: 0010013 | |
| 2017-08-30 08:27 | ickby | Note Added: 0010046 | |
| 2017-08-30 18:32 | Kunda1 | Note Added: 0010051 | |
| 2019-02-27 21:59 | Kunda1 | Summary | Boolean -> Difference leaves a extra hole => Boolean -> Difference leaves a extra hole (upstream OCC bug) |
