| 0002025 | Arch | Bug | public | 2015-03-25 22:14 | 2017-03-10 20:33 |
| Reporter | mackrorysd | Assigned To | kkremitzki | ||
| OS | Linux | OS Version | Fedora 20 | ||
| Summary | 0002025: Incrementing / decrementing measurements upgrades the units | ||||
| Description | If I enter a dimension in inches (e.g. '8"', or '8 in') in the 'data' form, when I edit it by clicking in the form element and hitting the up or down arrows to increment / decrement the measurement, it upgrades the units to yards. This makes it very difficult because every click of the button effects a change that is orders of magnitude larger than my units would imply I'm working with. In my opinion correct behaviour would be to use the current unit and increment / decrement by exactly one. | ||||
| Steps To Reproduce | Create a wall. Enter one of the dimensions in inches. Hit the up or down arrows to edit the dimension. | ||||
| Tags | units | ||||
I assume you have set you Units preference to "US customary", Are you talking about editing these values in the initial creation dialogue or the property editor (in combo view when the wall is selected) after creation? What version of FreeCAD are you talking about? Please post your Help about FreeCAD data. It is usually best to ask these questions in the forum first so we can filter issues and improve the bug ticket quality if one is needed. I could be wrong but I suspect you are using an old or obsolete FreeCAD version, as I don't seem to be able to duplicate your issue. OS: Ubuntu 12.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6240 (Git) Build type: Debug Branch: master Hash: fa42bc451ab6933a441d7be3680c1d17a25c33e8 Python version: 2.7.3 Qt version: 4.8.2 Coin version: 3.1.3 OCC version: 6.9.1.oce-0.18-dev |
@mackrorysd please respond to 0002025:0006737 |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20228 |
Since OP has not responded and it seems they are using an inferior version of FC, therefore resolving as 'unable to reproduce' |
| 2015-03-25 22:14 | mackrorysd | New Issue | |
| 2016-01-20 14:29 | jmaustpc | Note Added: 0006737 | |
| 2017-01-17 16:48 | Kunda1 | Note Added: 0007840 | |
| 2017-01-17 16:48 | Kunda1 | Status | new => feedback |
| 2017-01-19 13:19 | Kunda1 | Tag Attached: units | |
| 2017-01-25 22:34 | Kunda1 | Note Added: 0007992 | |
| 2017-02-02 13:21 | Kunda1 | Note Added: 0008170 | |
| 2017-02-02 13:21 | Kunda1 | Status | feedback => resolved |
| 2017-02-02 13:21 | Kunda1 | Resolution | open => unable to reproduce |
| 2017-02-02 13:21 | Kunda1 | Assigned To | => Kunda1 |
| 2017-02-02 13:21 | Kunda1 | Assigned To | Kunda1 => |
| 2017-03-10 20:33 | kkremitzki | Assigned To | => kkremitzki |
| 2017-03-10 20:33 | kkremitzki | Status | resolved => closed |
