| 0002038 | PartDesign | Feature | public | 2015-04-07 15:07 | 2018-08-26 18:38 |
| Reporter | larsen | Assigned To | kkremitzki | ||
| Summary | 0002038: Activate "Tasks" tab after creating a sketch | ||||
| Description | After creating a sketch, it would be convenient to not be shown the tree but the "Tasks" tab, as you normally want to pad or pocket. At least this is what I as a newbie do next. | ||||
The current behaviour is that the tab gets activated again which was active before the sketch is being edited. So, if you have the Tasks tab active it will jump back to this when leaving edit mode. > as you normally want to pad or pocket. At least this is what I as a newbie do next But it also often happens that you want to edit the sketch again. So, I think it's best to have an extra command to edit a sketch which will be available on the Tasks tab. Then we can always let it be active when leaving edit mode. |
I don't believe this bug is valid in 0.17 anymore. When I create a body and then a sketch, after closing the sketch, the task panel is active and I have the option to create sketch, pad, pocket, revolve, etc. |
@kkremitzki: You're right. Ticket can be closed IMHO. |
| 2015-04-07 15:07 | larsen | New Issue | |
| 2015-04-11 16:12 | wmayer | Note Added: 0006000 | |
| 2017-01-12 14:23 | Kunda1 | Tag Attached: #lowhangingfruit | |
| 2017-03-12 21:54 | kkremitzki | Note Added: 0008617 | |
| 2017-03-13 20:41 | larsen | Note Added: 0008622 | |
| 2017-03-13 20:42 | kkremitzki | Assigned To | => kkremitzki |
| 2017-03-13 20:42 | kkremitzki | Status | new => closed |
| 2017-03-13 20:42 | kkremitzki | Resolution | open => no change required |
| 2018-08-26 18:38 | Kunda1 | Tag Detached: #lowhangingfruit |
