| 0002045 | FreeCAD | Feature | public | 2015-04-10 02:47 | 2017-10-01 19:19 |
| Reporter | fhteagle | Assigned To | wmayer | ||
| Priority | low | Severity | minor | Reproducibility | have not tried |
| Summary | 0002045: Make Euler Rotation default or user-pref default | ||||
| Description | When trying to rotate anything via parameters, the default rotation input is not the Euler method. However, I think most users can operate the Euler method far more efficiently and effectively. I would like to see either: 1. Make Euler the default parameter entry mode, or 2. Create a preference toggle to make Euler the default parameter entry mode. Thanks | ||||
| Tags | rotate | ||||
| 2015-04-10 02:47 | fhteagle | New Issue | |
| 2015-04-10 06:10 | shoogen | Relationship added | related to 0002007 |
| 2017-01-24 00:11 | Kunda1 | Tag Attached: rotate | |
| 2017-09-15 10:47 | wmayer | Target Version | => 0.17 |
| 2017-10-01 19:19 | wmayer | Assigned To | => wmayer |
| 2017-10-01 19:19 | wmayer | Status | new => closed |
| 2017-10-01 19:19 | wmayer | Resolution | open => fixed |
| 2017-10-01 19:19 | wmayer | Fixed in Version | => 0.17 |
| 2017-10-01 19:19 | wmayer | Note Added: 0010228 |
