| 0002050 | FreeCAD | Bug | public | 2015-04-12 19:08 | 2017-01-27 03:41 |
| Reporter | drei | Assigned To | yorik | ||
| Priority | normal | Severity | block | Reproducibility | sometimes |
| Platform | 64 bit | OS | Arch Linux | ||
| Summary | 0002050: FreeCAD freezes when adding a Draft Dimension | ||||
| Description | Opening the file and attempting to create a Draft dimension generates a freeze in FreeCAD. OS: Linux Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.4805 (Git) Branch: master Hash: 3e1e5974f0b064a7e357cd593227c1cd21901bdb Python version: 2.7.9 Qt version: 4.8.6 Coin version: 3.1.3 OCC version: 6.8.0.oce-0.17 | ||||
| Steps To Reproduce | See video: http://youtu.be/NcG08wg1etg Open FreeCAD Open attached file Go to Draft Workbench Select Working Plane Select Add Dimension Select Origin | ||||
| Additional Information | Forum post: http://forum.freecad.org/viewtopic.php?f=3&t=10502 User quick61 mentions he was unable to reproduce the issue. gdb is unable to present information from bt since I am forced to do killall freecad in order to exit it. Here's what I can get from the terminal: gdb ./FreeCAD GNU gdb (GDB) 7.9 Copyright (C) 2015 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "x86_64-unknown-linux-gnu". Type "show configuration" for configuration details. For bug reporting instructions, please see: <http://www.gnu.org/software/gdb/bugs/> Find the GDB manual and other documentation resources online at: <http://www.gnu.org/software/gdb/documentation/> For help, type "help". Type "apropos word" to search for commands related to "word"... Reading symbols from ./FreeCAD...(no debugging symbols found)...done. (gdb) run Starting program: /home/isaac/Programs/Original/build/bin/FreeCAD [Thread debugging using libthread_db enabled] Using host libthread_db library "/usr/lib/libthread_db.so.1". FreeCAD 0.16, Libs: 0.16R4783 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## [New Thread 0x7fff937fe700 (LWP 1270)] [New Thread 0x7fff92ffd700 (LWP 1271)] Draft workbench activated Pick a face to define the drawing plane Pick first point: [Thread 0x7fff937fe700 (LWP 1270) exited] [Thread 0x7fff92ffd700 (LWP 1271) exited] kill [Thread 0x7ffff7f897c0 (LWP 1262) exited] Program terminated with signal SIGKILL, Killed. The program no longer exists. (gdb) kill The program is not being run. (gdb) bt No stack. (gdb) However, other times it works perfectly. | ||||
| Tags | OCC Bug | ||||
It seem that it is the Intersection snap tool that cause the freeze. |
I can't reproduce this problem, either with the intersection snap or not (I also tried several combinations). It is true that snapping gets slower when all the snap tools are turned on, but it doesn't freeze, and I can select the central intersection... |
I can confirm enabling Intersection snap produces this behaviour. It works fast with all other snap modes enabled except for Intersection snap. Disabling al other snap modes and enabling just Intersection snap will produce reported behaviour in few seconds. P.S. Ubuntu 14.04 + Daily PPA. |
I think i can reproduce the problem in DRAWEXE > time "distmini d s1 s2" http://tracker.dev.opencascade.org/view.php?id=26064 |
could everybody please tell if he used a debug or a release build when trying to reproduce the problem. |
Hi Shoogen, I don't really know... :( I build FreeCAD : OS: Ubuntu 14.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.4806 (Git) Branch: master Hash: a7c346606fe588b0f2faa251e3ae72e9ef833184 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 I usually just check FREECAD_USE_EXTERNAL_PIVY and in this case BUILD_FEM_NETGEN. I think I have read that debug is automatically ON. How can I check that please ? |
IFAIK Ubuntu daily PPA builds are now by default release builds due to discovered reduced sketcher performance when using debug builds. Therefore i am using release build. |
My complete CMake Configuration cmake ../FreeCAD_Master -DPYTHON_EXECUTABLE=/usr/bin/python2 -DFREECAD_USE_EXTERNAL_PIVY=1 -DBUILD_FEM=1 -DBUILD_CAM=0 -DBUILD_COMPLETE=0 -DBUILD_IMAGE=0 -DBUILD_INSPECTION=0 -DBUILD_OPENSCAD=0 -DBUILD_PLOT=0 -DBUILD_POINTS=0 -DBUILD_REVERSEENGINEERING=0 -DBUILD_SHIP=0 -DBUILD_ROBOT=0 -DBUILD_SPREADSHEET=1 -DBUILD_ASSEMBLY=0 -DCMAKE_BUILD_TYPE=Release -DFREECAD_USE_3DCONNEXION=0 -DNGLIB_INCLUDE_DIR=/opt/netgen/lib I'll test with Debug later today. |
Made a debug build. I let the software stay for a while after the freeze and in recovered. I'm still unable to get bt output. CMake config: cmake ../FreeCAD_Master -DPYTHON_EXECUTABLE=/usr/bin/python2 -DFREECAD_USE_EXTERNAL_PIVY=1 -DBUILD_FEM=1 -DBUILD_CAM=0 -DBUILD_COMPLETE=0 -DBUILD_IMAGE=1 -DBUILD_INSPECTION=0 -DBUILD_OPENSCAD=0 -DBUILD_PLOT=0 -DBUILD_POINTS=0 -DBUILD_REVERSEENGINEERING=0 -DBUILD_SHIP=0 -DBUILD_ROBOT=0 -DBUILD_SPREADSHEET=1 -DBUILD_ASSEMBLY=0 -DCMAKE_BUILD_TYPE=Debug -DFREECAD_USE_3DCONNEXION=0 -DNGLIB_clear gdb output: (gdb) run The program being debugged has been started already. Start it from the beginning? (y or n) y Starting program: /home/isaac/Programs/Original/build/bin/FreeCAD [Thread debugging using libthread_db enabled] Using host libthread_db library "/usr/lib/libthread_db.so.1". FreeCAD 0.16, Libs: 0.16R4812 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Attach observer 0x908a00 Attach observer 0x91c640 Attach observer 0xfe4310 Attach observer 0x10342f8 Attach observer 0x10374f8 Attach observer 0x10374f8 Attach observer 0x10fde70 [New Thread 0x7fff93218700 (LWP 3511)] Attach observer 0x1bfb318 Attach observer 0x1ba4d90 Draft workbench activated Pick first point: DraftGeomUtils: Unsupported curve type: (<BSplineCurve object>, <Line (-16,6,0) (0.0914546,6,0) >) DraftGeomUtils: Unsupported curve type: (<BSplineCurve object>, <Line (-30,-36,0) (-30,-38.8482,0) >) DraftGeomUtils: Unsupported curve type: (<BSplineCurve object>, <Line (-30,-36,0) (-30,-38.8979,0) >) DraftGeomUtils: Unsupported curve type: (<BSplineCurve object>, <Line (-30,-36,0) (-30,-38.9103,0) >) DraftGeomUtils: Unsupported curve type: (<BSplineCurve object>, <Line (-30,-36,0) (-30,-41.0592,0) >) DraftGeomUtils: Unsupported curve type: (<BSplineCurve object>, <Line (0,0,0) (-0.690785,-0.723034,-0.00625354) >) DraftGeomUtils: Unsupported curve type: (<BSplineCurve object>, <Line (-30,-36,0) (-30,-39.9351,0) >) DraftGeomUtils: Unsupported curve type: (<BSplineCurve object>, <Line (-30,-36,0) (-30,-39.9351,0) >) Pick first point: [Thread 0x7fff93218700 (LWP 3511) exited] DraftGeomUtils: Unsupported curve type: (<BSplineCurve object>, <Line (0,0,0) (-8.5,0,0) >) Detach observer 0x1bfb318 Detach observer 0x1ba4d90 Detach observer 0x91c640 Detach observer 0x10374f8 Detach observer 0x10374f8 Detach observer 0xfe4310 Detach observer 0x10342f8 Detach observer 0x10fde70 Detach observer 0x908a00 [Thread 0x7ffff7f887c0 (LWP 3506) exited] [Inferior 1 (process 3506) exited normally] (gdb) bt No stack. |
Okay I got it to crash too... If you keep hovering the mouse without clicking for a minute or two, it indeed ends up freezing, but not necessarily on the center of the model, and not necessarily with the dimension tool. Gdb doesn't register a crash. shoogen's find might be related, but maybe not the culprit... I still couldn't make sure if only the intersection snap causes the freeze |
The shapes that caused the problem were parallel lines. >>> App.ActiveDocument.dist1_s1.Shape.BoundBox BoundBox (-16, -36, 0, -7.5, -36, 0) >>> App.ActiveDocument.dist1_s2.Shape.BoundBox BoundBox (-18, 11, 0, -7.10543e-15, 11, 0) Perhaps it makes sense to check the Bounding Box before calling dist2shape. |
git fetch git://github.com/5263/FreeCAD dev-snapinter |
Added, thanks! Let's see if it solves... |
http://tracker.dev.opencascade.org/view.php?id=26075 |
I'll keep on testing a bit with the file, but the problem appears to have been solved. |
I can confirm enabling Intersection snap does not produce this behaviour any more. |
Okay, let's close this report then? If anyone needs to, please reopen! |
I don't consider completely disabling the distToShape call a "solution" |
I think this can be closed, I don't know what else needs to be done here... |
| 2015-04-12 19:08 | drei | New Issue | |
| 2015-04-12 19:08 | drei | File Added: robot_automatismos.fcstd | |
| 2015-04-12 20:26 | rockn | Note Added: 0006008 | |
| 2015-04-12 22:59 | yorik | Note Added: 0006009 | |
| 2015-04-12 23:27 | triplus | Note Added: 0006010 | |
| 2015-04-13 09:27 | shoogen | Note Added: 0006012 | |
| 2015-04-13 09:27 | shoogen | Tag Attached: OCC Bug | |
| 2015-04-13 10:20 | shoogen | Note Edited: 0006012 | |
| 2015-04-13 10:20 | shoogen | Assigned To | => shoogen |
| 2015-04-13 10:20 | shoogen | Status | new => assigned |
| 2015-04-13 10:21 | shoogen | Status | assigned => acknowledged |
| 2015-04-13 17:44 | shoogen | Note Added: 0006014 | |
| 2015-04-13 18:02 | rockn | Note Added: 0006015 | |
| 2015-04-13 19:17 | triplus | Note Added: 0006016 | |
| 2015-04-13 21:03 | drei | Note Added: 0006017 | |
| 2015-04-13 23:08 | drei | Note Added: 0006018 | |
| 2015-04-13 23:17 | yorik | Note Added: 0006019 | |
| 2015-04-14 06:31 | shoogen | Note Added: 0006020 | |
| 2015-04-14 06:31 | shoogen | Assigned To | shoogen => yorik |
| 2015-04-14 06:31 | shoogen | Status | acknowledged => assigned |
| 2015-04-14 06:40 | shoogen | Note Added: 0006021 | |
| 2015-04-14 06:40 | shoogen | Status | assigned => feedback |
| 2015-04-14 13:14 | yorik | Note Added: 0006024 | |
| 2015-04-14 13:20 | yorik | Changeset attached | => FreeCAD Master master 7ddd9d2c |
| 2015-04-14 15:12 | shoogen | Note Added: 0006025 | |
| 2015-04-14 15:12 | shoogen | Relationship added | parent of 0001931 |
| 2015-04-15 08:22 | shoogen | Relationship added | parent of 0002057 |
| 2015-04-17 04:22 | drei | Note Added: 0006036 | |
| 2015-04-17 04:22 | drei | Status | feedback => assigned |
| 2015-04-17 15:04 | triplus | Note Added: 0006037 | |
| 2015-04-17 15:04 | triplus | Note Edited: 0006037 | |
| 2015-04-17 16:40 | yorik | Note Added: 0006038 | |
| 2015-04-17 16:41 | yorik | Status | assigned => closed |
| 2015-04-17 16:41 | yorik | Resolution | open => fixed |
| 2015-04-17 16:41 | yorik | Fixed in Version | => 0.16 |
| 2015-04-17 19:37 | shoogen | Note Added: 0006040 | |
| 2015-04-17 19:37 | shoogen | Status | closed => feedback |
| 2015-04-17 19:37 | shoogen | Resolution | fixed => reopened |
| 2017-01-11 16:45 | yorik | Note Added: 0007632 | |
| 2017-01-11 16:45 | yorik | Status | feedback => closed |
| 2017-01-11 16:45 | yorik | Resolution | reopened => fixed |
| 2017-01-27 03:41 | Kunda1 | Relationship added | related to 0002182 |
