| 0002055 | FreeCAD | Bug | public | 2015-04-13 12:03 | 2017-03-10 20:30 |
| Reporter | andreast | Assigned To | kkremitzki | ||
| Platform | Intel | OS | Windows | OS Version | 8.1 x64 |
| Summary | 0002055: Undo and redo of fillet restore it incorrectly | ||||
| Description | Undo and redo of fillet restore it to the wrong level in Label & Attributes-tree | ||||
| Steps To Reproduce | New Part workbench Add a cube (in my example a cube with a cylindric hole) Add fillet with r=1mm to all four top edges (Screenshot capture_04132015_010249.jpg) Click Edit, Undo Click Edit, Redo *** Result: BUG! Label Fillet is restored and the 3D display shows the object correctly prior to Undo but the Fillet label is now on the same level as Cut. Label Fillet has no sub labels. (Screenshot capture_04132015_010519.jpg) (Save file as freecad-015-test002_005.FCStd) *** Closing and reopening the document will correct the label tree *** Result: OK. Label fillet is now at the correct level with Cut below it. (Screenshot capture_04132015_010659.jpg) | ||||
| Tags | undo | ||||
@andreast can you recreate on 0.16 or even in the lastest master ? CC @NormandC |
@Kunda1, yes bug still present. OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6706 (Git) Build type: Release Branch: releases/FreeCAD-0-16 Hash: f86a4e411ff7848dea98d7242f43b7774bee8fa0 Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
This is fixed in current master (see attached animated GIF). Clicking on Undo, then Redo, the Fillet operation reappears in the Model tree, and the Cut object is automatically nested under Fillet. OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10276 (Git) Build type: None Branch: master Hash: 10191e90861cf0c87d24c1980761fd1c7f3cdde4 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
| 2015-04-13 12:03 | andreast | New Issue | |
| 2015-04-13 12:03 | andreast | File Added: FreeCAD 015 label tree undo-redo bug 2.zip | |
| 2015-04-13 12:08 | andreast | File Added: capture_04132015_010249.jpg | |
| 2015-04-13 12:09 | andreast | File Added: capture_04132015_010519.jpg | |
| 2015-04-13 12:09 | andreast | File Added: freecad-015-test002_005.FCStd | |
| 2015-04-13 12:10 | andreast | File Added: capture_04132015_010659.jpg | |
| 2017-01-18 22:02 | Kunda1 | Tag Attached: undo | |
| 2017-02-04 03:42 | Kunda1 | Relationship added | related to 0002504 |
| 2017-02-04 03:46 | Kunda1 | Relationship added | related to 0002387 |
| 2017-02-23 20:33 | Kunda1 | Assigned To | => Kunda1 |
| 2017-02-23 20:33 | Kunda1 | Status | new => feedback |
| 2017-02-23 20:33 | Kunda1 | Note Added: 0008411 | |
| 2017-02-23 20:42 | andreast | Note Added: 0008412 | |
| 2017-02-23 20:42 | andreast | Status | feedback => assigned |
| 2017-02-25 18:04 | normandc | File Added: FC_issue#2055_fixed.gif | |
| 2017-02-25 18:04 | normandc | Note Added: 0008431 | |
| 2017-02-25 21:37 | Kunda1 | Assigned To | Kunda1 => |
| 2017-02-25 21:37 | Kunda1 | Status | assigned => resolved |
| 2017-02-25 21:37 | Kunda1 | Resolution | open => fixed |
| 2017-02-25 21:37 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-03-10 20:30 | kkremitzki | Assigned To | => kkremitzki |
| 2017-03-10 20:30 | kkremitzki | Status | resolved => closed |
