| 0002080 | FEM | Bug | public | 2015-05-01 13:54 | 2017-10-18 17:53 |
| Reporter | pfirszt | Assigned To | wmayer | ||
| Summary | 0002080: Attempt to remove FEM analysis result (displacement & stress) results in false warning | ||||
| Description | Attempt to remove FEM analysis result (displacement & stress) results in false warning: "This object is referenced by other objects and thus these objects might get broken. Are you sure to continue?" | ||||
| Steps To Reproduce | Run analysis, select Displacement or MissesStress, press "Del" key | ||||
| Additional Information | http://forum.freecadweb.org/viewtopic.php?f=18&t=10771&p=86698#p86695 | ||||
| Tags | FEM | ||||
PopUp is still in 0.17.8048. Yes, we should may be remove that popup. It is not needed. |
PopUp still in 0.17.9791. The PopUp pops up on press del dey for any analysis member. If the results are deleted by purge results command the popup does not pop up. I'm gone give it a try if it is possible to solve in python. bernd |
I opened a forum topic http://forum.freecadweb.org/viewtopic.php?f=18&t=20196 |
wmayer responds in the thread: |
https://github.com/FreeCAD/FreeCAD/commit/c1542e24015e8103185ef47fb8fb2215a6f4df38 https://github.com/FreeCAD/FreeCAD/commit/dcaf263e4c36215bbf09d11d57909e60b5ad5f2e |
| 2015-05-01 13:54 | pfirszt | New Issue | |
| 2016-03-21 16:44 | berndhahnebach | Tag Attached: FEM | |
| 2016-03-22 10:49 | berndhahnebach | Project | FreeCAD => FEM |
| 2016-07-28 23:28 | berndhahnebach | Note Added: 0007225 | |
| 2017-01-24 12:15 | berndhahnebach | Note Added: 0007951 | |
| 2017-01-24 12:38 | berndhahnebach | Status | new => confirmed |
| 2017-01-24 20:58 | berndhahnebach | Note Added: 0007971 | |
| 2017-02-20 22:26 | Kunda1 | Note Added: 0008391 | |
| 2017-02-20 22:27 | Kunda1 | Target Version | => 0.17 |
| 2017-10-18 17:53 | wmayer | Assigned To | => wmayer |
| 2017-10-18 17:53 | wmayer | Status | confirmed => closed |
| 2017-10-18 17:53 | wmayer | Resolution | open => fixed |
| 2017-10-18 17:53 | wmayer | Fixed in Version | => 0.17 |
| 2017-10-18 17:53 | wmayer | Note Added: 0010319 |
