| 0002091 | Robot | General | public | 2015-05-06 23:09 | 2021-02-06 06:37 |
| Reporter | philius | Assigned To | |||
| Platform | amd64 | OS | Debian | OS Version | 8.0 |
| Summary | 0002091: 3D printer simulator - a new nodekit? | ||||
| Description | I tried understanding how the robots example works, but as a newbie the number of external references is daunting. I want to create a 3D printer model in freecad that shows a delta printer, although any other printer would help, but I'm using delta printer terms below. Its shows its print volume - the area it can 3D print in, in a different color. There are a couple of sliders to change: Delta arm length: affects print volume width+height Linear actuator length: affects print height, required linear bearings diameter Base radius: affects print area Delta arm distance: affects actuactor dimensions (the actuator is connected by 3 arm-pairs) which affects the print volume width It looks like the 6-axis robot model was developed outside of freecad, but it would be great if such models could be developed, edited and shared through freecad! | ||||
Something like http://www.thinkyhead.com/_delta/ but with a translucent print volume with some sliders. |
Interesting developments in the Path WB: https://forum.freecadweb.org/viewtopic.php?f=10&t=24923&p=196416#p196414 |
@kunda1 This is not sketcher related. Do we need a robot WB project? |
CC @yorik |
Okay I added a Robot subproject. |
This ticket has been migrated to GitHub as issue 5628. |
| 2015-05-06 23:09 | philius | New Issue | |
| 2015-05-07 11:12 | philius | Note Added: 0006124 | |
| 2017-10-23 18:35 | Kunda1 | Note Added: 0010344 | |
| 2017-12-19 13:36 | abdullah | Note Added: 0010620 | |
| 2017-12-19 14:39 | Kunda1 | Note Added: 0010621 | |
| 2017-12-29 13:56 | wmayer | Project | Sketcher => FreeCAD |
| 2018-01-05 19:34 | yorik | Note Added: 0010710 | |
| 2018-01-05 19:35 | yorik | Project | FreeCAD => Robot |
| 2021-02-06 06:37 | abdullah | Target Version | => 0.20 |
