| 0002100 | Spreadsheet | Feature | public | 2015-05-14 05:34 | 2021-11-24 15:31 |
| Reporter | FreeCadder | Assigned To | |||
| Summary | 0002100: Spreadsheet: Additional Inverse Display Units | ||||
| Description | It would be nice if in addition to "K^-1" there could be cell display units like "1/K" or "/K" or "K?¹", see code below. | ||||
| Steps To Reproduce | App.newDocument("Unnamed") App.setActiveDocument("Unnamed") App.ActiveDocument=App.getDocument("Unnamed") Gui.ActiveDocument=Gui.getDocument("Unnamed") App.activeDocument().addObject('Spreadsheet::Sheet','Spreadsheet') App.ActiveDocument.Spreadsheet.set('B1', 'Feature /K') App.ActiveDocument.Spreadsheet.set('C1', 'Feature 1/K') App.ActiveDocument.Spreadsheet.set('D1', 'Feature 1/°C') App.ActiveDocument.Spreadsheet.set('E1', 'Feature 1/°F') App.ActiveDocument.Spreadsheet.set('F1', 'Feature K?¹') App.ActiveDocument.Spreadsheet.set('G1', 'Workaround K^-1') App.ActiveDocument.Spreadsheet.set('A2', 'Linear Expansion Coefficient') App.ActiveDocument.Spreadsheet.set('B2', '1.6e-4') App.ActiveDocument.Spreadsheet.set('C2', '1.6e-4') App.ActiveDocument.Spreadsheet.set('D2', '1.6e-4') App.ActiveDocument.Spreadsheet.set('E2', '1.6e-4') App.ActiveDocument.Spreadsheet.set('F2', '1.6e-4') App.ActiveDocument.Spreadsheet.set('G2', '1.6e-4') App.ActiveDocument.Spreadsheet.setDisplayUnit('B2', '/K') App.ActiveDocument.Spreadsheet.setDisplayUnit('C2', '1/K') App.ActiveDocument.Spreadsheet.setDisplayUnit('D2', '1/°F') App.ActiveDocument.Spreadsheet.setDisplayUnit('E2', '1/°C') App.ActiveDocument.Spreadsheet.setDisplayUnit('F2', 'K?¹') App.ActiveDocument.Spreadsheet.setDisplayUnit('G2', 'K^-1') App.ActiveDocument.Spreadsheet.setColumnWidth('A', 180) App.ActiveDocument.Spreadsheet.setColumnWidth('G', 120) App.ActiveDocument.recompute() # Application->Unnamed->Spreadsheet: "Show spreadsheet" | ||||
| Tags | #post-to-forum, spreadsheet | ||||
'K?¹' = U+004B U+207B U+00B9 |
# other useful workarounds App.ActiveDocument.Spreadsheet.set('H1', 'Workaround m/m/K') App.ActiveDocument.Spreadsheet.set('H2', '1.6e-4') App.ActiveDocument.Spreadsheet.setDisplayUnit('H2', 'm/m/K') App.ActiveDocument.Spreadsheet.set('I1', 'Workaround mm/m/K') App.ActiveDocument.Spreadsheet.set('I2', '1.6e-4') App.ActiveDocument.Spreadsheet.setDisplayUnit('I2', 'mm/m/K') App.ActiveDocument.Spreadsheet.setColumnWidth('H', 130) App.ActiveDocument.Spreadsheet.setColumnWidth('I', 130) App.ActiveDocument.recompute() # fails? App.ActiveDocument.Spreadsheet.set('J1', 'Workaround µm/m/K') App.ActiveDocument.Spreadsheet.set('J2', '1.6e-4') App.ActiveDocument.Spreadsheet.setDisplayUnit('J2', 'µm/m/K') # U+00B5 App.ActiveDocument.Spreadsheet.setColumnWidth('J', 130) App.ActiveDocument.recompute() |
Reminder sent to: eivindkvedalen @eivindkvedalen would you kindly weigh in on this? |
@FreeCadder do you mind re-upping code-utf8.txt ? |
The unit Kelvin is available in FreeCAD. The above code does not work anymore. The code App.ActiveDocument.Spreadsheet.setDisplayUnit('B2', '/K') gives: Failed to parse expression. So there is some improvement in FreeCAD to avoid false expectations. What remains is the feature request for the addition of °C and °F to the quantity-framework. |
@ulrich1a is there a feature request open for that yet ? |
@ulrich1a please respond Also @eivindkvedalen care to weigh in ? |
This ticket has been migrated to GitHub as issue 5629. |
| 2015-05-14 05:34 | FreeCadder | New Issue | |
| 2015-05-14 05:39 | FreeCadder | File Added: code-utf8.txt | |
| 2015-05-14 05:40 | FreeCadder | Note Added: 0006131 | |
| 2015-05-14 06:29 | FreeCadder | Note Added: 0006132 | |
| 2015-05-14 06:44 | FreeCadder | Note Edited: 0006132 | |
| 2017-01-19 14:24 | Kunda1 | Tag Attached: spreadsheet | |
| 2017-02-10 11:29 | Kunda1 | Note Added: 0008263 | |
| 2017-07-17 11:21 | Kunda1 | Note Added: 0009766 | |
| 2017-07-17 11:21 | Kunda1 | Status | new => feedback |
| 2017-08-23 12:02 | Kunda1 | Tag Attached: #post-to-forum | |
| 2017-08-23 12:03 | Kunda1 | Note Added: 0009999 | |
| 2017-12-13 15:27 | Kunda1 | Project | FreeCAD => Expressions |
| 2018-05-04 20:44 | ulrich1a | Note Added: 0011229 | |
| 2018-08-26 15:36 | Kunda1 | Note Added: 0011666 | |
| 2018-08-26 15:37 | Kunda1 | Note Edited: 0011666 | |
| 2019-07-23 23:44 | Kunda1 | Note Added: 0013379 | |
| 2021-11-24 15:31 | chennes | Project | Expressions => Spreadsheet |
