| 0002114 | PartDesign | Bug | public | 2015-05-23 05:54 | 2017-03-08 19:08 |
| Reporter | bthistlethwaite | Assigned To | kkremitzki | ||
| Platform | Dell Inspiron 17R | OS | Windows | OS Version | 8 Pro |
| Summary | 0002114: When creating a partial elliptical toroid using the sweep function some segment angles produce consistently incorrect results | ||||
| Description | I need to create a specific segment of a toroid that uses a complete elliptical profile and a partial elliptical sweep. If the sweep ellipse uses Angle0 and Angle1 values that are more than 180 degrees apart, then the resulting solid is correct. If the sweep ellipse uses Angle0 and Angle1 values that are less than 180 degrees apart but span the 180 degree line, then the resulting solid is correct. If however, the sweep ellipse uses Angle0 and Angle1 values that are less than 180 degrees apart but do not span the 180 degree line, then the resulting solid is incorrect and sometimes wildly incorrect. | ||||
| Steps To Reproduce | Using the Part Workbench, Part and Create Primitives, create an ellipse with a nominally sized full ellipse (with Angle 1 = 0, Angle 2 = 360). Using the Part Workbench, Part and Create Primitives, create another ellipse with a larger full-sized ellipse (with Angle 1 = 0, Angle 2 = 360). Change the smaller ellipse so that it is located with its central meridian at one end of the major axis and with its plane orthogonal to the plane of the larger ellipse and the plane of the smaller ellipse in the same plane as the major axis of the larger ellipse. Now the elliptical toroid should resemble an elliptical wrist bangle and be complete. Now experiment by adjusting both Angle0 and Angle1 of the larger ellipse so that the resulting segment becomes smaller, and so that the displayed segment appears in different positions around the larger ellipse. Inconsistencies in the resulting shape should become obvious at this point. | ||||
| Additional Information | I will upload a file that illustrates one of the scenarios that I described, where the segment should be between 45 and 135 degrees. | ||||
| Tags | sweep | ||||
Please retest on latest stable or development versions. |
I feel the issue stems from an incomplete understanding of the sweep tool. The sweep profile should always be located at either ends or along the sweep path. Moreover, it should be normal to the path. In the attached file by the reporter, the sweep profile is a good distance from the partial ellipse path, and is not normal to the path. Hence, the resulting sweep is not located along the path, and the profile is not constant. If the profile is properly placed, then the sweep works exactly as expected. Therefore I consider this bug invalid. |
| 2015-05-23 05:54 | bthistlethwaite | New Issue | |
| 2015-05-23 05:54 | bthistlethwaite | File Added: Part-Elliptical-Toroid-Broken-For-Particular-Angles-B.FCStd | |
| 2017-02-17 13:50 | Kunda1 | Status | new => feedback |
| 2017-02-17 13:50 | Kunda1 | Note Added: 0008335 | |
| 2017-02-17 13:50 | Kunda1 | Tag Attached: sweep | |
| 2017-02-25 18:24 | normandc | File Added: Part-Elliptical-Toroid-with-proper-placement_normandc1.FCStd | |
| 2017-02-25 18:24 | normandc | Note Added: 0008433 | |
| 2017-02-25 21:40 | Kunda1 | Status | feedback => resolved |
| 2017-02-25 21:40 | Kunda1 | Resolution | open => no change required |
| 2017-03-08 19:08 | kkremitzki | Assigned To | => kkremitzki |
| 2017-03-08 19:08 | kkremitzki | Status | resolved => closed |
