| 0002121 | Part | Feature | public | 2015-05-25 08:20 | 2017-06-28 14:19 |
| Reporter | herrdeh | Assigned To | |||
| Summary | 0002121: part workbench - extrude - apply thickness to extruded polygone paths | ||||
| Description | When I do a "extrude" from a polygone path, the item created would remain flat, which I rarely would use in the real world. I can make it thicker by the x,y,z-axis - but not alongside the polygone path. You could do a sweep alongside your polygone path, but that's quite some work. | ||||
| Steps To Reproduce | part workbench create a polygone path (sketch or wire) assign "extrude" tool" look for "Thickness" control besides the "direction" controls look in vain | ||||
| Tags | Part | ||||
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20148 |
Per @DeepSOIC > 2D offset feature should fulfill the need, I think. |
Closing as no response from @herrdeh |
| 2015-05-25 08:20 | herrdeh | New Issue | |
| 2015-05-25 08:20 | herrdeh | File Added: extrude_thickness.png | |
| 2017-01-23 12:33 | Kunda1 | Note Added: 0007917 | |
| 2017-05-03 04:05 | Kunda1 | Tag Attached: Part | |
| 2017-05-10 19:57 | Kunda1 | Project | FreeCAD => Part |
| 2017-05-31 12:18 | Kunda1 | Severity | major => minor |
| 2017-05-31 12:19 | Kunda1 | Note Added: 0009219 | |
| 2017-05-31 12:20 | Kunda1 | Status | new => feedback |
| 2017-06-28 14:19 | Kunda1 | Status | feedback => closed |
| 2017-06-28 14:19 | Kunda1 | Resolution | open => no change required |
| 2017-06-28 14:19 | Kunda1 | Note Added: 0009575 |
